Post by barney on Sept 26, 2017 17:39:26 GMT 1
Well I'm just starting my rebuild 350lc so wish me luck, I've been sourcing various bits over the past 6months and have today started to put things into place, im going to rebuild fairly standard with a few upgrades,the bike isn't going to be for sale so so its for my own satisfaction on a Sunday blast๐ So to start barrels are at Pjme being rebored frame is at the powder coaters swinging arm and a few other bits are at the polishers I will be posting up some pics as I go along,just need to set it up 1st and of course I will be asking stupid questions so please bear with me
Post by dusty350 on Sept 26, 2017 19:48:55 GMT 1
Good luck, and above all, enjoy the process Dusty
Post by Topman350 on Sept 26, 2017 20:48:25 GMT 1
Best of luck with the build mate and enjoy ๐๐
Post by yamark on Sept 26, 2017 21:49:20 GMT 1
Hope your build goes well Barney. Looking forward to seeing your progress, so post up some pics when you get a chance
Cheers, Mark
Post by barney on Sept 26, 2017 22:28:27 GMT 1
Right just trying the app I've installed to ad some pics as I go along Hopefully should have a pic of something
Post by morgy on Sept 27, 2017 7:20:08 GMT 1
Looking forward to see your build...
Post by mikee on Sept 27, 2017 9:36:50 GMT 1
get on with it then
mike
Post by abar121 on Sept 27, 2017 12:21:24 GMT 1
Good luck, looks like fun!
Post by barney on Oct 26, 2017 14:17:46 GMT 1
Been a bit slow waiting on parts to come back from various places, barrels are back from pjme rebored 2.5os head re-profiled and blasted ready for painting, Just picked up my crankcases from aqua blasters and am very happy with the nice clean finish, will now be able to start getting the motor together over the couple of weeks๐
Post by dusty350 on Oct 26, 2017 14:53:51 GMT 1
Looking good Barney Vapoured cases are always a good start. Have you done the gear shaft bush mod ? Worth doing at this stage if you haven't already Dusty
Post by barney on Oct 26, 2017 15:18:57 GMT 1
Looking good Barney Vapoured cases are always a good start. Have you done the gear shaft bush mod ? Worth doing at this stage if you haven't already Dusty Yes they sure look nice๐ what is the mod on the gear shaft bush? cheers
Post by dusty350 on Oct 26, 2017 15:41:57 GMT 1
Hi The area where the steel gear shaft passes through the Lc case on the sprocket side is ally, and can wear over the years where the harder steel shaft passes through it. On the later Ypvs cases, Yamaha fitted a steel bush to save wear on the case. Norbo sells a PTFE lined bush in his shop that you can fit into the Lc case to solve any wear issues. The existing hole needs to be reamed out as the bush is an interference fit. Now is the time to do it before you build the bottom end. I can add a couple of pics later - Flikr isn't working for me at the moment Dusty
Post by arrow on Oct 26, 2017 16:55:02 GMT 1
Nice project. Good work on the build.
Post by barney on Oct 26, 2017 19:02:38 GMT 1
Hi The area where the steel gear shaft passes through the Lc case on the sprocket side is ally, and can wear over the years where the harder steel shaft passes through it. On the later Ypvs cases, Yamaha fitted a steel bush to save wear on the case. Norbo sells a PTFE lined bush in his shop that you can fit into the Lc case to solve any wear issues. The existing hole needs to be reamed out as the bush is an interference fit. Now is the time to do it before you build the bottom end. I can add a couple of pics later - Flikr isn't working for me at the moment Dusty Ok I think I know what your on about, itโs on norbo page stating itโs 20 mm longer and needs reeming, if you could post up a pick that would be good though๐ As you said whilst the bikes at this state any mods that will benefit the built should be done๐ cheers
Post by barney on Oct 26, 2017 19:03:55 GMT 1
Nice project. Good work on the build. At least I know the oil pumps going be right๐๐
Post by dusty350 on Oct 26, 2017 19:58:22 GMT 1
Hi mate, here you are; 20160205_094843_zpsmgdcjhuu by David Miller, on Flickr and from inside the gearbox; 20160205_094906_zpsgtjuo5xf by David Miller, on Flickr When I built my 350lc engine, I wanted to future proof it as much as possible. I did buy a reamer off ebay but then decided it could be expensive if I didn't get it right, so I took it to my local engineers who measured it all up, reamed out the hole and pressed the bush into place - cost me a tenner ! Worth doing at this stage in my opinion. Dusty
Post by barney on Oct 26, 2017 20:34:21 GMT 1
Thanks dusty that's great๐ Yes I agree with you on future proofing as much as you can on the build, luckily for me one of my mates who I raced with is a CNC machinist and just loves two strokes and just so happens to be helping me build the motor( or should I say I'll be making the coffee whilst he puts it together๐๐) Cheers Barney
Post by dusty350 on Oct 26, 2017 20:42:33 GMT 1
Brilliant, then I would get him to do it. Common oil leaks can usually be traced to either the gear shaft oil seal or the neutral switch cover. If the shaft is a sloppy fit due to wear in the case, then the oil seal is gonna have a harder time stopping oil leaking past. Same as the gear shaft itself. The oil seal can wear a groove in the shaft so even with a new seal, oil can leak past the worn area. Dusty
Post by dusty350 on Oct 26, 2017 20:48:28 GMT 1
And I should add, I'm sure someone on here mentioned they did the bush mod at the other end of the shaft, where it passes through the case on the clutch side. Obviously not an oil leak issue, but more to support the shaft equally at both ends. Yamaha didn't go that far with the pv cases, and don't know if it's really necessary but for the cost of a bush, and an extra cup of coffee, it may be worth doing. Dusty
Post by barney on Oct 26, 2017 21:01:23 GMT 1
Iโm just in the process of putting a order together for norbo and on the list is a new gear shaft as mine has slight wearing on where the seal sits, probably be ok but I donโt want to put it all together and have to pull it apart again, makes sense to put two bushes as youโve said will balance it up and stop the wear...... Best get the kettle on๐๐
Post by barney on Nov 29, 2017 21:14:19 GMT 1
Well not a lot to report sadly as been busy redoing the bathroom, got a few more goodies arrive though including my freshly rechromed forks from Phillpots ๐๐ A sparkly refurbed oil pump from arrow Top bloke and top job๐ Frame is ready for collection at the powder coaters Engine is ready to go back together so hopefully will be posting some updates of a actual rebuild not just bits๐
Post by Mr Kipling on Nov 29, 2017 21:32:32 GMT 1
looks like its coming together nicely , Gary always does a top job..+1 on that...
Post by barney on Nov 29, 2017 22:30:43 GMT 1
looks like its coming together nicely , Gary always does a top job..+1 on that... Gary found out it was a 250 pump with the incorrect worm drive so was a potential seizure waiting to happen,so glad I sent it to him
Post by Mr Kipling on Nov 29, 2017 22:52:28 GMT 1
looks like its coming together nicely , Gary always does a top job..+1 on that... Gary found out it was a 250 pump with the incorrect worm drive so was a potential seizure waiting to happen,so glad I sent it to him Money well spent me thinks !!!
Post by barney on Dec 5, 2017 18:57:32 GMT 1
Ohhh more shiney stuff picked๐๐
Post by dusty350 on Dec 5, 2017 19:08:42 GMT 1
Oooh, shiny Looks great Dusty
Post by peebee on Dec 5, 2017 22:34:33 GMT 1
Hi The area where the steel gear shaft passes through the Lc case on the sprocket side is ally, and can wear over the years where the harder steel shaft passes through it. On the later Ypvs cases, Yamaha fitted a steel bush to save wear on the case. Norbo sells a PTFE lined bush in his shop that you can fit into the Lc case to solve any wear issues. The existing hole needs to be reamed out as the bush is an interference fit. Now is the time to do it before you build the bottom end. I can add a couple of pics later - Flikr isn't working for me at the moment Dusty Thats good information Dusty, does anyone know if it's the same on a YPVS engine case ? Cheers. EDIT, Actually I'm just gonna go down the shed right now and have a look at mine.
Post by barney on Dec 5, 2017 22:45:17 GMT 1
Oooh, shiny Looks great Dusty I do like shiny๐๐๐
kevm
Post by kevm on Dec 5, 2017 23:21:37 GMT 1
What swingarm and forks are you using ?
Post by dusty350 on Dec 6, 2017 8:39:18 GMT 1
Peebee - the Ypvs cases has the bush fitted as standard. Yamaha must have realised the effect a steel shaft turning in an alloy housing needed some modification to prevent wear and subsequent leaks. Dusty
