Post by plumma on Aug 13, 2017 3:13:38 GMT 1
Just wondering if anybody has used a 31k rear master with the hybrid rgv caliper or do you need a rgv master
Post by Yogi on Aug 13, 2017 8:15:08 GMT 1
It works fine mate just make sure the brake hose ain't too tight If it is it can undo when the swinger moves up n down
Matt
Post by plumma on Aug 13, 2017 8:42:29 GMT 1
Cheers, just wanted to make sure the master cylinder bore size was compatible with the rgv caliper. That way it's an easy conversion not having to modify master cylinder mount.
Post by gammaguy21 on Aug 15, 2017 16:49:06 GMT 1
Thanks for the info Yogi. I was also wondering about this. Any chance you tell me what length brake hose you ended up using?
Post by Yogi on Aug 15, 2017 20:17:04 GMT 1
Thanks for the info Yogi. I was also wondering about this. Any chance you tell me what length brake hose you ended up using? Hi mate Mine measures 28in bolt to bolt It's got an r6 Brembo master on now because the original was knackered Matt
Post by Yogi on Aug 15, 2017 20:18:15 GMT 1
Cheers, just wanted to make sure the master cylinder bore size was compatible with the rgv caliper. That way it's an easy conversion not having to modify master cylinder mount. You can use an r6 Brembo without any mods Matt
Post by JonW on Aug 15, 2017 23:32:38 GMT 1
FYI Most master cylinders have their size on them, the OEM ypvs is a 5/8 as is the RGV... therefore they will work the same.
Post by plumma on Aug 16, 2017 1:47:49 GMT 1
Great info fellas, nice to be able to keep all original brackets for ease of reassembly
Post by gammaguy21 on Aug 16, 2017 16:44:02 GMT 1
Hi mate Mine measures 28in bolt to bolt It's got an r6 Brembo master on now because the original was knackered Matt Awesome, thanks Matt!
