Post by chrismac on Nov 12, 2005 21:35:06 GMT 1
I wanted to strip down the caliper on my RD 250 LC, the piston is very stiff even when using the the brake system I can not get the piston out. It will move a bit. Help!! What can I do?
Post by mellow on Nov 12, 2005 22:15:21 GMT 1
try usin 2 pairs of water pump plier thingys n havin them opposite each other on one piston at a time and try to squeeze the piston in but u must squeeze it squarley.thats wot usually works for me :)good luck
4l0
Post by 4l0 on Nov 13, 2005 7:37:57 GMT 1
I wanted to strip down the caliper on my RD 250 LC, the piston is very stiff even when using the the brake system I can not get the piston out. It will move a bit. Help!! What can I do? drop the calliper in boiling hot water then try,but to be honest i use boiling hot water and a air line. :obut be careful where you point it ;D ;D .the piston will fly out
Post by chrismac on Nov 13, 2005 17:11:14 GMT 1
Try Mole grips on the pisten it will put marks on it but if you are replacing it then who cares. Put the caliper in a vice and just rock the pison back and forth with the grips. Simple and it will pull it out I was hoping not to have to change the piston only the seals! Any other ideas, going to have something to eat then I'm off to my cold garage for another play!!
Post by chrismac on Nov 13, 2005 17:18:05 GMT 1
I wanted to strip down the caliper on my RD 250 LC, the piston is very stiff even when using the the brake system I can not get the piston out. It will move a bit. Help!! What can I do? drop the calliper in boiling hot water then try,but to be honest i use boiling hot water and a air line. :obut be careful where you point it ;D ;D .the piston will fly out I,m going to give this a go, but haven't got an air line If I drop it in the boiling water and pump the leaver do you think the fluid will push it out?
Post by Norbo on Nov 13, 2005 17:43:33 GMT 1
I think it will do the job as the alloy will expand and the heat will soften the seals in the caliper helping you to pumt it out.
4l0
Post by 4l0 on Nov 14, 2005 18:48:52 GMT 1
definitley ;D ;)messy but it,ll work
gazmo
The missus said Ive out grown the bike I dont see what the problem is!
Post by gazmo on Nov 18, 2005 0:42:02 GMT 1
Post by Norbo on Nov 18, 2005 13:57:31 GMT 1
It's ok mate i just want to keep the site reletively cleen thats all. I dont want want it turning in to the back yard if you know what i mean.
Post by chrismac on Nov 18, 2005 19:56:35 GMT 1
The cold weather is making it very had to release my brakes.
There in the garage and I'm not!!!!
Post by chrismac on Nov 20, 2005 0:28:19 GMT 1
Post by Norbo on Nov 21, 2005 13:16:07 GMT 1
If the pison has'nt got to much rust on it then new seals will do they are just £5 . If the piston has a lot of rust on it then you need the pison as well £19 for the kit
Post by vinze187 on Nov 21, 2005 13:24:18 GMT 1
True careful style! PMSL!!
