Post by donkeychomp on Jul 26, 2017 22:43:46 GMT 1
Hi lads (and lasses)3
Has anyone fitted one of these to an LC? I've seen a few on ebay but there are no clear fitting guides, surely something needs to replace both cables. I'm hoping to use on on a hybrid I'll be building (thread not yet started!) so any advice would be a great help!
Post by Mr Kipling on Jul 26, 2017 22:48:11 GMT 1
yeah few of the lads have fitted digi speedo,s what type u fitting???
Speedo usual pick,s up from magnet rpm normally from pulse from ur coil..
Post by donkeychomp on Jul 26, 2017 22:52:03 GMT 1
No idea what one to buy. Prices vary wildly, I just need one with speedo, rev counter and water temp really!
Post by 0h5h1t on Jul 26, 2017 23:01:50 GMT 1
I used a koso RX2 Unit on my build, has all the functions you require and a few more. You can see pictures in my build thread. I also used the koso speedo adapter so speed is picked up from the speedo drive as I didn't like the brackets for the magnet approach.
Post by Mr Kipling on Jul 26, 2017 23:03:06 GMT 1
Koso,s are good Vapor too , all comes down to looks price n what functions u need ... if ur feeling flush Translogic are nice ( well they are till u drop em )...
Post by markhoopy on Jul 26, 2017 23:39:05 GMT 1
I've got a Koso RX2N+ that I will happily swap for £115 if that's what you're after
Post by rigga on Jul 27, 2017 5:11:03 GMT 1
Few guys have some some real trick set ups, with digital units mounted in the original clock cases, mix of modern and original which I really like, Dave (muttsnuts on here) might be able to advise on that
Post by jackjabba on Jul 27, 2017 15:12:12 GMT 1
I have a Koso DB-03R on one of my bikes, its ok and does the job but will be changing for a Translogic Micro dash. next year.
Post by Mr Kipling on Jul 27, 2017 15:37:50 GMT 1
Post by donkeychomp on Jul 27, 2017 21:25:14 GMT 1
Cheers! Going to go read a few build threads.
Post by Kryten on Jul 28, 2017 15:54:38 GMT 1
My Koso uses a GPS sensor attached under the plastic electrics panel on my F2 hybrid .Saves using the magnets,brackets and cables.
Post by Tobyjugs on Jul 28, 2017 19:20:20 GMT 1
My Koso uses a GPS sensor attached under the plastic electrics panel on my F2 hybrid .Saves using the magnets,brackets and cables. Can you go a bit deeper into that. At the moment i have no provision for a speedo pick up maybe this is a good Solution for me.
Post by markhoopy on Jul 28, 2017 19:25:11 GMT 1
Post by Tobyjugs on Jul 28, 2017 19:30:15 GMT 1
Thanks Mark, thats a nice idea and is probably cheaper if you haven't got your own workshop.
Post by markhoopy on Jul 28, 2017 19:45:06 GMT 1
Thanks Mark, thats a nice idea and is probably cheaper if you haven't got your own workshop. Thinking about getting one myself just for the simplicity of setting it up compared to magnets etc .. £85 is far from cheap but it is a great little thing to have on any special.
Post by Kryten on Jul 28, 2017 19:54:04 GMT 1
It was an easier and neater solution for me as I have titanium disc bolts so the magnets would not stick in the holes,although i could have just used one steel bolt for the magnet.
Post by Tobyjugs on Jul 28, 2017 20:18:11 GMT 1
I think its a great idea
Post by Mr Kipling on Jul 28, 2017 20:45:59 GMT 1
Wired up the DB speedo today , works a treat , that gps sensor think that,ll be going on the other as the cable is too short for the rear , look neater too...thxs Mark more to buy..!!!
Post by fozzy17 on Jul 29, 2017 9:49:49 GMT 1
guys I have koso clocks on a bike I bought a few months ago, it needs speedo drive setup, that needs hooking up, but the other I need is temp sensor, what options did you guys go for that works, its a lc with ypvs motor
Post by jackjabba on Jul 29, 2017 10:36:28 GMT 1
Post by fozzy17 on Jul 29, 2017 11:15:33 GMT 1
Any other options? I was thing about one that bolts on head bolts, is that a option
Post by jackjabba on Jul 29, 2017 18:23:41 GMT 1
Post by fozzy17 on Jul 29, 2017 18:45:54 GMT 1
Yeah that might be a option, thanks fella
