Post by stusco on Jul 19, 2017 7:30:28 GMT 1
Now that my bike is run in I've been giving it a bit stick and it likes too rev ,infact I think it would rev right through the red on my lc clocks if I let it,what would you suggest the red line should be so I can set it with the zeel,Pv engine ,zeel,mick abbey fast road tune ,tea pipes,
Post by midlifecrisisrd on Jul 19, 2017 10:41:59 GMT 1
Prefer the coffee pipes myself
Kennys pipes should peak about 9600 but will rev into the red.
I programmed my zeel with a 10500 rev limit and a 9500 shift light
If you've used a new 4L3 clock cover there will be the spare idiot light for the speed warning light on the Jap bikes that you can fit a holder and an led lamp (faster response) and connect to the shift light output.
I used a Jap ypvs tacho for the same reason as it has the red speed warning light in it.
Also the mechanical rev counters can be inaccurate so the light at 9500 will show how far out it is
coose
Post by coose on Jul 19, 2017 10:52:15 GMT 1
What spec is the crank, and what does Mick say?
Post by headcoats on Jul 19, 2017 10:59:49 GMT 1
My Mick Abbey tune with TSA pipes, PWK carbs, v force etc made peak power at 10,200rpm but they reckon keep it under 10 grand If you have the Zeel and fix the limit , maybe allow for a bit of over rev too ?
My engine after several years is getting tired now so feathering it at around 9500 ! and a bit more for that panic overtake manoeuvre LOL
Post by stusco on Jul 19, 2017 15:01:03 GMT 1
My Mick Abbey tune with TSA pipes, PWK carbs, v force etc made peak power at 10,200rpm but they reckon keep it under 10 grand If you have the Zeel and fix the limit , maybe allow for a bit of over rev too ? My engine after several years is getting tired now so feathering it at around 9500 ! and a bit more for that panic overtake manoeuvre LOL Same spec as mine ,as Steve says I think I'll rig up up a shift light as well as it already there just need connecting
Post by Mr Kipling on Jul 19, 2017 15:30:31 GMT 1
set mine at 10,500 , I too use a jap spec rev counter in my hybrid which I currently use speed for shift light , used one on another hybrid before used it as an oil warning , pretty handy of Yamaha thinking ahead ...
Post by bare on Jul 19, 2017 18:08:25 GMT 1
Interesting factoid: At 10.5 k rpms the crank is facing more than ..Double... the loadings/wear than it is at 10k. RPM and wear/loadings are geometric with rpms Just saying.. that extra bit 'O power comes at a cost.
Post by headcoats on Jul 19, 2017 18:39:16 GMT 1
Ian Booms old bike which had a very similar tune to mine with exactly the same TSA pipes but had the full Zeeltronic ignition made more power at less revs , about 9800 it made 71 BHP I guess worth fitting the Zeel just to bring those killer revs down,Pretty sure it was the Zeel doing this
Red line
Jul 19, 2017 18:55:00 GMT 1
via mobile
Post by midlifecrisisrd on Jul 19, 2017 18:55:00 GMT 1
Interesting factoid: At 10.5 k rpms the crank is facing more than ..Double... the loadings/wear than it is at 10k. RPM and wear/loadings are geometric with rpms Just saying.. that extra bit 'O power comes at a cost. Agree totally. Absolute max revs for me is 10k The 10500 limiter is just a failsafe in case I make an arse of it Steve
antos
Red line
Jul 19, 2017 19:33:19 GMT 1
via mobile
Post by antos on Jul 19, 2017 19:33:19 GMT 1
Just jumping in here lads my f2 rebuilt everything 😊 Seems to run out of steam at 8.5-9k it's bog standard, new norbo yam reeds banchee coils, crank done at Grampian motors, it'll pull to 9.5 but not willingly . Is this the norm
Red line
Jul 19, 2017 19:41:10 GMT 1
via mobile
Post by midlifecrisisrd on Jul 19, 2017 19:41:10 GMT 1
Just jumping in here lads my f2 rebuilt everything 😊 Seems to run out of steam at 8.5-9k it's bog standard, new norbo yam reeds banchee coils, crank done at Grampian motors, it'll pull to 9.5 but not willingly . Is this the norm Get some spannies on it Steve
antos
Red line
Jul 19, 2017 23:06:09 GMT 1
via mobile
Post by antos on Jul 19, 2017 23:06:09 GMT 1
Lol when funds allow Steve 😉
Post by bare on Jul 20, 2017 17:55:11 GMT 1
Ian Booms old bike which had a very similar tune to mine with exactly the same TSA pipes but had the full Zeeltronic ignition made more power at less revs , about 9800 it made 71 BHP I guess worth fitting the Zeel just to bring those killer revs down,Pretty sure it was the Zeel doing this Fiddling with the PV settings can give Happy result. Factory onset and full opening points make little sense and produce small perf gains.
