Post by wangwang on Jul 16, 2017 16:19:55 GMT 1
Post by veg on Jul 16, 2017 19:28:37 GMT 1
At a guess Sr400/500 however the rear sprocket throws me. I also think under the black plastic cover you may have bolt holes for a twin disc set up?
Post by wangwang on Jul 16, 2017 19:33:57 GMT 1
At a guess Sr400/500 however the rear sprocket throws me. I also think under the black plastic cover you may have bolt holes for a twin disc set up? Think I've sussed the rear, it's a later XT500. I'll try and get the cover off and see if the front looks any more familiar.
Post by cb250g5 on Jul 16, 2017 19:50:16 GMT 1
If there's no cush drive on that rear, I'd suspect TT500
Post by wangwang on Jul 16, 2017 20:02:29 GMT 1
I removed the boss and the plastic cover on the front wheel. the spindle diameter seems to be 18mm.
Post by bezzer on Jul 16, 2017 21:04:09 GMT 1
If there's no cush drive on that rear, I'd suspect TT500 Also if it's a TT500 rear, the spokes would be radially mounted & the hub itself would be magnesium 👍🏻
Post by veg on Jul 16, 2017 21:10:36 GMT 1
Twin disc front normally are xs650 however I think the later sr400/500 also had the same type of hub
Post by wangwang on Sept 2, 2017 21:04:15 GMT 1
Twin disc front normally are xs650 however I think the later sr400/500 also had the same type of hub Pretty sure you are correct, can now get bearings etc. cheers
Post by KevtheRev on Sept 2, 2017 21:10:10 GMT 1
My guess was SR . Anyone remember the cool little window they had to let you know she was TDC for a good hard boot ?? Could've done with one on my XR !!
Post by veg on Sept 2, 2017 21:34:57 GMT 1
Had an xt500 they were the same felt like a real man booting it. I was only 20
Post by Norbo on Sept 3, 2017 7:30:59 GMT 1
cant help with what they are but they do look ace what ever they are
Post by jon on Sept 3, 2017 7:59:12 GMT 1
Wangwang, how many teeth has the rear sprocket got?
Post by wangwang on Sept 3, 2017 11:30:13 GMT 1
Post by jon on Sept 3, 2017 12:05:36 GMT 1
Are you using them on an RD? If so I might have just the thing you'll probably need. It's a brand new in the packet gold anodised talon sprocket for an XT500 but with 39 teeth. Jon
Post by wangwang on Sept 3, 2017 12:28:35 GMT 1
Are you using them on an RD? If so I might have just the thing you'll probably need. It's a brand new in the packet gold anodised talon sprocket for an XT500 but with 39 teeth. Jon Yes, eventually they will be going in an LC, as they're 17" rims probably be in a non standard arm. Let me know what you want for it, cheers.
