Post by jollyr6 on Jul 15, 2017 20:47:14 GMT 1
Hi can anyone recommend a plastic glue /epoxy for repairing plastic Tia jolly
Post by wangwang on Jul 15, 2017 20:51:23 GMT 1
Post by mattybeckett on Jul 15, 2017 23:34:19 GMT 1
Qbond is the Daddy.. Available on ebay
Post by LC_BOTT on Jul 16, 2017 8:19:26 GMT 1
Post by muddyfox on Jul 16, 2017 9:08:41 GMT 1
I make lego glue for my plastics and you have choice in colours
Post by jollyr6 on Jul 17, 2017 14:13:12 GMT 1
I make lego glue for my plastics and you have choice in colours Ay totally cofuseled now
Post by muddyfox on Jul 17, 2017 19:42:48 GMT 1
Most fairings snd panels are made from the same stuff lego is, called abs plastic So you cut up lego into small slithers Get some 99% pure acertone just a small amount, mix your lego into the acertone, mash it up till it turns into a paste bit like toothpaste Feed it into your cracks and wipe excess off and leave to dry What it does is fuse the plastic together as if you didnt have any cracks Good as new
Post by jollyr6 on Jul 18, 2017 11:22:16 GMT 1
Most fairings snd panels are made from the same stuff lego is, called abs plastic So you cut up lego into small slithers Get some 99% pure acertone just a small amount, mix your lego into the acertone, mash it up till it turns into a paste bit like toothpaste Feed it into your cracks and wipe excess off and leave to dry What it does is fuse the plastic together as if you didnt have any cracks Good as new ay that sounds intresting acertone u mean stuff i use to clean my nail varnish off with >>>>>>
Post by muddyfox on Jul 18, 2017 18:17:45 GMT 1
No your looking for pure acertone not nail polish remover, costs around £2 a litre
Post by jollyr6 on Jul 19, 2017 17:13:01 GMT 1
Got some bond question though filler or glue first? ?
Post by ozzysbikes on Jul 19, 2017 19:44:50 GMT 1
I had this dilemma a few months back and was pointed in the direction of the Wurth replast stuff, it turned out to be very good, in fact I was sceptical before using it but it formed a repair that seems as strong as a weld, however it is expensive so being a stereotypical Yorkshire man I found a cheaper alternative, the vendor when asked if it is as good as the Wurth stuff was quite indignant in saying "it's better" I used some of the cheaper stuff and it works as well as the Wurth replast, it is sold by a company called Wayside adhesives who have their own website or are on Ebay,
I have to add that correct use of it is crucial to a good result (as with all bonding)
no connection to Wurth or Wayside
Post by doohanno1 on Jul 27, 2017 17:59:49 GMT 1
Bonding : never my strong point..
Post by smallstroker on Aug 7, 2017 21:52:30 GMT 1
I have shaved a slither off the inside of a fairing where it can't be seen and melted it in to a small crack with a soldering iron perfect match
