Post by wangwang on Jul 15, 2017 15:47:07 GMT 1
Anyone put Air cooled alloys in an LC? I'm thinking of doing it for a project, is it just a case of getting alternative sized bearings to fit the LC spindles? Cheers Wang
Post by veg on Jul 15, 2017 17:54:38 GMT 1
Weren't the rear wheels disc brake? I know Sr and Xs had drums though, could be and probably am wrong.
Post by wangwang on Jul 15, 2017 19:26:44 GMT 1
Weren't the rear wheels disc brake? I know Sr and Xs had drums though, could be and probably am wrong. Yes they are, but it's not a problem for what i'm doing ;-)
Post by zedixe13 on Jul 16, 2017 5:28:39 GMT 1
I would go for the Daytona / 400E-F wheels as they are lighter and wider .
Post by wangwang on Jul 16, 2017 10:57:04 GMT 1
I would go for the Daytona / 400E-F wheels as they are lighter and wider . Do you know the sizes?
Post by rich on Jul 16, 2017 13:56:29 GMT 1
That's a prototype in the pic, those wheels never made it to production on the LC. As you know, the aircooled RD had a disc rear and I think the front spindle may be a different diameter to the LC so you could fit aircooled wheels but it will take a bit of fettling. Think the rim sizes were same as the LC ones.
Post by wangwang on Jul 16, 2017 16:14:01 GMT 1
That's a prototype in the pic, those wheels never made it to production on the LC. As you know, the aircooled RD had a disc rear and I think the front spindle may be a different diameter to the LC so you could fit aircooled wheels but it will take a bit of fettling. Think the rim sizes were same as the LC ones. I discovered the problem with the front spindle, as I had an old A/C wheel knocking about. It should be do-able if I can get the correct bearing sizes though??
Post by rich on Jul 16, 2017 16:32:27 GMT 1
Oh yes, anything is do-able, just the amount of work that varies!
Post by russpuss on Jul 16, 2017 16:52:42 GMT 1
Andy Jones pre production LC
Post by bare on Jul 16, 2017 17:55:22 GMT 1
Great! Was there an axle size issue? If so did you redrill the fork holes.. or ? And what width are those rims.. Memory claims they were wider than the LC ones.. are they ?
Post by yamman1066 on Jul 16, 2017 18:11:53 GMT 1
thats andys 4l1000007 bike
Post by zedixe13 on Jul 17, 2017 7:40:59 GMT 1
I would go for the Daytona / 400E-F wheels as they are lighter and wider . Do you know the sizes? Later RD400 are 1.85 in front and 2.15 rear .
Post by mattybeckett on Jul 17, 2017 17:02:17 GMT 1
Oh yes, anything is do-able, just the amount of work that varies! Like most women
