Post by JonW on May 22, 2023 0:20:30 GMT 1
test using a chromebook. i have tried on my post a few days ago, i couldn't do it, but another member was able to with the link. What am i doing wrong ? Jon, if you look at the text on where you posted above, what i did was cut out the part where it had a square bracket and then IMG all the way until the same thing with a / in it. The bits that say IMG in the brackets are the tags, the first one says to the forum 'this thing is an image' the last one with the slash says 'this is the end of the image'. the bit inside those tags is the link to the pic itself and where its hosted. Those the the only bits of all the text you need. you can see some of that in the pic from imgur that i posted above. Here is an example: HTH
rdjon
Post by rdjon on May 22, 2023 10:31:42 GMT 1
I will have to prcatice.
Post by KevtheRev on Jun 7, 2023 18:07:07 GMT 1
A quick youtube vid is very easy to upload , and all you have to do is post a link . Not much good for those classic 80's Polaroids I know , but still handy . Here's my bother firing up his LC ,
And here's mine . Taxed and on the road now
