Post by liffy16 on Jun 24, 2017 10:05:13 GMT 1
Would I be correct in assuming that the lc2 and n1 fork springs are the same? pretty sure they are but would like some confirmation many thanks in advance col
Post by howard on Jun 24, 2017 13:15:29 GMT 1
I bought a pair of wirth springs for my 31k forks and they sent F2 type that are much thicker , I ended up buying a pair of Hagons from Norbo for the smaller waisted type forks .
Post by midlifecrisisrd on Jun 24, 2017 14:24:07 GMT 1
Lc2 and n1 are different
N1 springs are shorted as they use a spacer on top
Post by paulincayman on Jun 24, 2017 15:40:26 GMT 1
I bought a pair of wirth springs for my 31k forks and they sent F2 type that are much thicker , I ended up buying a pair of Hagons from Norbo for the smaller waisted type forks . Howard Can you recall how did the spring lengths compare between the wirth and hagon? Paul
Post by howard on Jun 24, 2017 17:32:19 GMT 1
Not sure as I didn't have both around at the same time but I do remember the Hagen being around 2" longer than the standard ones I removed .
Post by budgie on Jun 24, 2017 18:35:29 GMT 1
Howard, were the Hagons linear or progressive...?
Gavin
Post by paulincayman on Jun 24, 2017 19:18:24 GMT 1
Not sure as I didn't have both around at the same time but I do remember the Hagen being around 2" longer than the standard ones I removed . Thanks Howard I'm only asking because I'm going to be using f2 forks to accommodate the triumph four pot calipers in my 4lo...going to shorten them to stock lc length and I'm still a bit unclear what to buy. Had just about settled on 31k springs as same length as 4lo (I think) and 35mm fitment as f2. But from what you just posted on the wirths I'm unsure again. I'm now thinking stock f2 springs trimmed down as per Bare's suggestion in another thread.
Post by paulincayman on Jun 24, 2017 19:20:58 GMT 1
And apologies to liffy17 for crashing your thread.
antos
Post by antos on Jun 25, 2017 0:10:58 GMT 1
Just as a side note I went with the triumph callipers and boy, sooo much better👍
Post by liffy16 on Jun 25, 2017 20:39:31 GMT 1
ok thanks will get some hagons
