Ypvs pins
Jun 17, 2017 20:57:09 GMT 1
via mobile
Post by 3tj6 on Jun 17, 2017 20:57:09 GMT 1
Hi all got some power valves of ebay, but there's no pins in them ? Where can i get some? Or can you use something else? To join them together? Tia jon
Post by jon on Jun 18, 2017 8:54:59 GMT 1
I will measure their diameter later, and post size if no-one beats me to it.
I suspect you could just buy metal bar and saw to length, then dress up ends if you want to go the DIY route.
They always look shiney, so I suspect they are plated? I could make some on a lathe your stuck, but they would be unplanted mild steel.
Post by Yogi on Jun 18, 2017 8:59:01 GMT 1
Cant you just cut some small drill bits to fit
Matt
Post by jon on Jun 18, 2017 17:32:40 GMT 1
Good idea Matt!
They are 3mm diameter.
Post by 1966baz on Jun 18, 2017 20:39:15 GMT 1
I bought 3mm steel dowels on ebay as I needed some .As ssid above they are 3mm diameter and 17 mm long. Cheers.
Post by rich on Jun 18, 2017 21:19:42 GMT 1
I bought 3mm steel dowels on ebay as I needed some .As ssid above they are 3mm diameter and 17 mm long. Cheers. Me too
