Post by headcoats on Jun 14, 2017 9:14:15 GMT 1
Need the little bracket that is welded onto the LC rear brake pedal Does anyone have the dimensions for the bracket that has to be welded on and a few pics of the position please ?
Post by dusty350 on Jun 14, 2017 11:29:42 GMT 1
Hi I've seen a few variations but this works on mine; Obviously the bottom is modded, top is standard. Return spring is an issue due to the actuating rod, but I found an exhaust spring which is narrowin section, works a treat; Hth Dusty
Post by dusty350 on Jun 14, 2017 11:30:03 GMT 1
Post by dusty350 on Jun 14, 2017 11:30:41 GMT 1
Post by paulincayman on Jun 14, 2017 15:27:17 GMT 1
Dusty , is that a one way valve at the end of the reservoir tube ? I have to do the same conversion using F2 wheels, brakes .. Paul
Post by dusty350 on Jun 14, 2017 17:53:54 GMT 1
Hi Paul Just a stopper as far as I know - stops the brake fluid covering the back end of the bike. You can buy a nice ally stopper off ebay - search Tygon tubing I think. I want to shorten the tube - it looks wrong being as long as it is - as long as there is enough fluid for the brake system to work plus a little free space. Seen it done on front brakes and looks far better.
Dusty
Post by headcoats on Jun 14, 2017 18:34:13 GMT 1
Great pictures , Thanks
Do you have an actual measurement of the little bracket please ?
Post by dusty350 on Jun 14, 2017 21:04:51 GMT 1
Hi Sorry for the triple post - Proboards kept telling me it had a problem when it obviously didn't !! I did make a paper template of it -it's somewhere in the garage. I will find it and let you know the dims Regards Dusty
Post by paulincayman on Jun 15, 2017 14:01:31 GMT 1
Cheers Dusty.
