jarvy
Post by jarvy on Jun 4, 2017 14:17:36 GMT 1
Hi everyone,
Just thought I would introduce myself.
Originally from Kent I now live in Switzerland and have just bought a 250 4L1.
Pretty much original just needs a bit of a tidy up or so I thought. Picked it up yesterday and half way home it seized solid at 80 kph,
luckily I'm of an age (56) that used to ride 2 strokes back in the late 70s so knew what to do (clutch in coast to a stop). So now
it sits at a breakdown yard from where I will fetch it on Tuesday. Oh well I did want a project!
It registered here in Switzerland as a vintage machine so that's a maximum of 3000kms per year and an inspection every 6 years
(like an MOT).
Safe riding Ian (Jarvy)
Post by paulincayman on Jun 4, 2017 14:29:32 GMT 1
Welcome aboard and good luck..you'll find all the help and info here.
Post by dusty350 on Jun 4, 2017 14:31:04 GMT 1
Hi Ian Welcome to the forum, and welcome back to the unpredictable world of two strokes !! Hope the seizure isn't too bad. Regards Dusty
Post by 17again on Jun 4, 2017 18:43:15 GMT 1
welcome to the forum
Post by essexblue on Jun 4, 2017 19:50:33 GMT 1
Welcome to the forum buddy.
Sorry to hear about the engine problem
Post by Mr Kipling on Jun 4, 2017 21:41:25 GMT 1
hi an welcome to the fold , good luck with the rebuild , we all kid ourselves ref the quick tidy up !!!
Post by Ozhammer on Jun 6, 2017 9:01:25 GMT 1
Well you sure squeezed the full gamut of emotions into your first day of returning to two stroke ownership didn't you and they sure can be cruel mistresses eh?
Hope you get it sorted swiftly without too much expense and welcome to the fold.
Rgds Ozhammer
jarvy
Post by jarvy on Jun 6, 2017 17:40:18 GMT 1
Thanks for the welcome, Got it home today and started to strip down the engine. Head off nothing yet.
Post by arrow on Jun 6, 2017 19:41:41 GMT 1
Welcome to the forum.
Post by SquALeD on Jun 7, 2017 13:19:11 GMT 1
Hi jarvy
newb here too but not to lcs...used to live up the road from you in essex, now live in western oz...also workin on a 250lc
jarvy
Post by jarvy on Jun 7, 2017 16:37:14 GMT 1
Top end all good so engine is now out on the bench.
So still not sure why its seized. No overheating before hand, no odd noises that would indicate
bearing failure it just stopped.
Will split the cases when the manual arrives just winging it so far!
Post by iwantalc on Jun 7, 2017 21:16:08 GMT 1
where abouts in kent did you live ?
Post by mattybeckett on Jun 7, 2017 23:43:22 GMT 1
Welcome aboard the forum :-) good luck with strip down and hopefully not to bad.
jarvy
Post by jarvy on Jun 8, 2017 6:55:16 GMT 1
Grew up in Headcorn then Canterbury area then Dover area. Still have a house near Folkestone but have lived in the USA since 2008. Moved to Switzerland last September.
jarvy
Post by jarvy on Jun 20, 2017 10:19:51 GMT 1
I am still awaiting some tools to fully strip the engine but in the mean time I have a question. On taking out the air filter I found it to be perished with a big part of it missing. So having checked every where what damage would the lumps of foam do to the engine?
Post by Deleted on Jun 20, 2017 16:22:00 GMT 1
I think you may know the answer to that question I fear
Post by midlifecrisisrd on Jun 20, 2017 16:56:53 GMT 1
The foam itself won't do any damage but the weak fuel mixture will make it run lean and potentially seize
jarvy
Post by jarvy on Jun 20, 2017 17:48:28 GMT 1
With a weak mixture wouldn't the top end seize first? No marks in the top end and plugs look ok. Looks like a rebuilt crank then only trouble is not sure about that here in Switzerland. So then next question is anyone know of some where in the SE of England that can rebuild the crank in a few days as I do get back regularly?
Post by midlifecrisisrd on Jun 20, 2017 19:02:00 GMT 1
If the top end is OK then a main bearing would be my first thought
If they are left not running the bearings can pit
They initially seem fine but will self destruct soon after
Could be oil starvation so ideally get the pump checked/rebuilt. Arrow on here does it very reasonably
As for crank rebuild either pjme in Wolverhampton or Grampian motors in Liverpool.
Both these are in the Midlands unfortunately but Grampians will usually turn a crank around in 24 hours and ship back
jarvy
Post by jarvy on Jun 21, 2017 16:52:23 GMT 1
Ok then its the right main bearing. It seems to have self destructed as midlifecrisisrd said as it seems to have been stood a while.
ace
Post by ace on Jun 21, 2017 17:23:24 GMT 1
Good luck with the rebuild and welcome to the forum mate.......
jarvy
Post by jarvy on Jun 22, 2017 14:08:27 GMT 1
So do I just buy a new crank, it seems a lot easier to buy a nice new one from PJME than shipping the worn one to the UK and having it rebuilt and shipped back.
Post by midlifecrisisrd on Jun 22, 2017 18:46:06 GMT 1
The thing is it should be cheaper to get it rebuilt as hopefully the website will be reusable
At £40 a Web it adds up.
Unless the bearings Have spun or the taper and keyway on the flywheel side are damaged
jarvy
Post by jarvy on Jul 10, 2017 6:38:16 GMT 1
Post by wuckfitracing on Jul 10, 2017 18:28:28 GMT 1
Ian where in Switzerland are you. Currently in Bern myself working.
jarvy
Post by jarvy on Jul 10, 2017 18:41:03 GMT 1
I live just outside Zug
Post by liffy16 on Jul 10, 2017 18:50:43 GMT 1
Welcome aboard ! did'nt think you would be allowed to run a stinky two stroke in swiss lol!
Post by wuckfitracing on Jul 10, 2017 20:06:24 GMT 1
About 1 1/2 hours from Bern. Only asking as we have chaps that drive back and forth to the UK, might have been able to take some bits back for you. One drove back this morning. Currently commisioning a test train for SPB.
gsomos
Post by gsomos on Jul 22, 2017 19:51:33 GMT 1
Welcome to the Forum!
