Post by petehodges on Jun 3, 2017 23:20:14 GMT 1
Thought my troubles were behind me with Lc more or less finished took it out for a run today & at around 80mph the back wheel locked on dual carriageway how I held it up I don't know a mate picked me up & said too works get rid like you all I've put my heart & soul into this fooked bike I'm now sick of it gutted
Post by doohanno1 on Jun 3, 2017 23:34:10 GMT 1
I don"t mean to be an asshole but was 80 mph not a bit harsh on a fresh motor.. Also something could of went astray with the carbs.. Sh*t happens Take a deep breath and go again..
wib
Post by wib on Jun 4, 2017 2:53:02 GMT 1
What do the plugs look like? Lean? 80 km is not the problem how bad do they treat a race motor.
Post by JonW on Jun 4, 2017 3:09:41 GMT 1
Did you leakdown test this?
Post by Eyrey1 on Jun 4, 2017 3:16:05 GMT 1
looks like a big air leak with a hole like that very lean get intouch with maccas on here or ebay he sells a good leakdown kit for about 30 quid my mates rd400 had a hole like that and he had a crack in the crankcase he had not seen
Post by crazydave on Jun 4, 2017 3:55:00 GMT 1
I have seen cheap/incorrect plugs do this many moons ago.
Post by steeley on Jun 4, 2017 5:54:44 GMT 1
Hmmm not good mate . as said when its rebuilt give it a leak down test. is the ignition rotor the correct one for a 31k motor the pick up looks long. I will have a look at the rotor on my 31k motor ,it my be just me my memory playing up on me. years ago had a similar event on my LC same sort of speed . I was messing about with a pair of bored out Tzr carbs . tried for years to get it to run right ,last year put std carbs and cable on and got rid of the bloody things Lol.
Post by Shytalk on Jun 4, 2017 7:56:36 GMT 1
Pete, the main thing is that you're okay and not in hospital, gutted for you though.
Post by iwantalc on Jun 4, 2017 8:18:08 GMT 1
as above could of been a lot more serious than a hole in a piston ..
Post by LC_BOTT on Jun 4, 2017 8:29:25 GMT 1
is the ignition rotor the correct one for a 31k motor the pick up looks long. That was the first thing I looked at, it's a long time since I rebuilt mine, so can't remember either, looks like a trigger has fallen off in the pic, so doubt that would cause a hole in the piston, might be worth checking the ignition system, and compatability of all the components together, as it seems a minefield of what works, if things have been swapped etc.
Post by Yogi on Jun 4, 2017 9:05:48 GMT 1
Gutted for ya Pete but luckily your ok
Put it to one side while you lick your wounds
Atb Matt
Post by dusty350 on Jun 4, 2017 9:15:02 GMT 1
Sorry to see that, but as the guys say, you kept it upright. Hard to feel good after something like this happens but if it had spat you off at 80mph, well, that doesn't bare thinking about. Throw a sheet over it, forget you even own an Lc, and do something else for a week or 2, then come back to it and see how you feel. Works for me !! Good luck Dusty
Post by arrow on Jun 4, 2017 9:34:54 GMT 1
Really sorry to hear about this. As the guys say, you walked away unhurt, which is the main thing.
Post by 4l04ever on Jun 4, 2017 11:05:07 GMT 1
A leak down test is compulsory before running a new engine if you want it to stay in one piece! Certainly looks like an air leak/major lean condition. Hopefully the crank will be okay after a clean.
As above, just take a break for a week or two, then strip it down and assess what needs doing. Rebuild, then do a leak down test.
Good luck
Post by Mr Kipling on Jun 4, 2017 21:51:53 GMT 1
as above peeps , chin up step back start again , deffo leak test before re-using new engine , peace of mind , good luck with the rebuild...
Post by Norbo on Jun 5, 2017 6:09:06 GMT 1
So sorry to hear this im proper gutted for you
reggit
Post by reggit on Jun 5, 2017 6:52:36 GMT 1
It's gutting, but only an engine at the end of the day. Mine popped last November and I'm only just getting round to doing something about it now. Put it in the garage and forget about it for a while!
Looks like that pot was running lean to me - I've got a few pistons in my collection with similar damage!
Post by 4l04ever on Jun 5, 2017 10:46:21 GMT 1
I hope they were not Yambits crank seals! The left crank seal failing could cause a major lean condition on left cylinder, as it could allow extra air into the left side.
Post by seanclarky on Jun 5, 2017 10:50:08 GMT 1
gutted for you pal, could've been worse though. These bikes can be frustrating but they are worth the hassle!
Post by Deleted on Jun 5, 2017 12:00:15 GMT 1
I feel your pain.
Post by alexx on Jun 5, 2017 12:15:18 GMT 1
have you put a head gasket on this surface .. ?
Post by mouse on Jun 5, 2017 13:23:43 GMT 1
I really feel for you, that is s***!
Hope you get it sorted
Mouse
Post by doohanno1 on Jun 5, 2017 14:55:39 GMT 1
Can you imagine that happening to this guy..!!
