Post by skint on May 21, 2017 22:32:33 GMT 1
Hi all, what's a good quality 2 stroke oil to use in my 350 lc these days? It has an oil pump not pre mixing. Any advice appreciated. Thanks.
Post by skydemon on May 21, 2017 22:55:56 GMT 1
lol the debate continues. A lot of us use Motul. The rest use other stuff. Search the forum. Loads of threads on it. Good luck 👍🏼
antos
Post by antos on May 23, 2017 14:52:56 GMT 1
Lol go on then I'll join in 😂 Running in my f2 on silkolene semi Once it's ran in I'll be giving her a drink of castrol power 1 fully synthetic 👍 All oils now are better than in the 80s👍
Post by headcoats on May 23, 2017 15:59:20 GMT 1
Exol Optima, the devil's spunk LOL
Seems to work OK
Post by bare on May 26, 2017 0:27:09 GMT 1
Most ANY oil is leagues More sophisticated... than the Oils specified when these Bikes were current. Unlikely to find oil anywhere near as low spec (relatively) as what was considered good stuff.. 'back then'. Oil quality isn't of concern.
Post by Jethro5 on May 26, 2017 1:32:06 GMT 1
Agree with bare. Any reputable brand that is specified for two strokes with oil injection will do the job. You have a lot of money invested however and its probably not going to do thousands of miles a year so that will limit oil consumption. So I'd go for a fully synthetic from Motul, Castrol etc.. Most important thing is to keep something in the oil tank!
Post by mudguts on May 26, 2017 6:22:28 GMT 1
exol optima
Post by Norbo on May 26, 2017 7:44:49 GMT 1
ANY GOOD QUALITY OIL IS OK PERSONALLY I USE MOTUL
Post by davey on May 26, 2017 8:39:39 GMT 1
I use motul 710 and buy fromt the net at about 9 quid a litre
Post by alexx on May 26, 2017 9:39:53 GMT 1
Post by sispeed on May 26, 2017 11:43:03 GMT 1
Used Liqui Moly for a while. All Liqui Moly oils are high quality oils. Not cheap but very good. The synth oil has only little smoke Regards Siggi
Post by alexx on May 26, 2017 12:31:57 GMT 1
Used Liqui Moly for a while. All Liqui Moly oils are high quality oils. Not cheap but very good. The synth oil has only little smoke Regards Siggi yes Liqie Moly is quite famous on good oils and additives
Post by jackjabba on May 26, 2017 13:15:00 GMT 1
If it meets the spec of the oil specified for the bike then its going to work.
Don't buy £20 a litre oil for £5 off the internet, its probably fake.
Don't use premix oil with an auto lube system, it says for Premix only for a reason.
