Post by oldenglishcars on May 13, 2017 19:05:37 GMT 1
Returning to a rd after many years I bought a 31k that needed work got everything working and repairs done but have problems with engine not revving above 7000ish rpm carbs cleaned out and float heights set, new plugs, idles well sounds good upto 7000ish then it's as if it's strangled. power valves opening, tried raising and lowering main needles, no different. exhausts clear. HELP.
Post by trappena on May 14, 2017 19:39:16 GMT 1
Fill us in on the state of the bike, stock or modified and if modified what are the modifications.
Not revving can have a few causes, could be as simple as blocked air filter. Try running without to see if it makes a difference.
Cheers
Post by oldenglishcars on May 16, 2017 9:48:06 GMT 1
As far as I know the bike is stock. it has been stood awhile. I totally stripped carbs and cleaned, new air filter, new plugs, new fuel, checked power valves work and open and close. Set float heights, balanced carbs, played with needle hights. stripped cards again and run through it all again but no change. it get to around 7000rpm and the just stops, then sounds strangled, no extra smoke but runs crap 7k plus below 7k runs great and sounds nice.
Post by stusco on May 16, 2017 10:04:10 GMT 1
Maybe exhausts are choked stopping it going into the powerband
Post by midlifecrisisrd on May 16, 2017 12:20:20 GMT 1
With such an abrupt stop in revs I'd think pv's rotating wrong way or high speed windings on the stator knackered
Both easy to check for
Post by muttsnuts on May 16, 2017 14:06:11 GMT 1
your power valves are 180 degrees out, take the cam off (cables fit to it), turn the power valves 180 degree's, refit the cam and try again
tomtom1
Leeds
Post by tomtom1 on Aug 15, 2019 21:50:28 GMT 1
Power valves 180 out, had exact same problem on my 31k, easy to sort.
