Post by mellow on Aug 21, 2006 18:45:44 GMT 1
hi peeps................can sum 1 enlighten me on the clutch adjustment plz........haynes manual dont make sense to me........its on about bar adjuster and inline adjuster which mine dont have if sum 1 could tell me should the pointer bit line up with the clutch lever in resting position or once the slack has been took up?? on mine at the moment if i set the slack to about 10mm as it should b the pointer is one side of the mark but if i take the slack up by pulling lever it goes to other side of mark so doesnt line up whichever way cheers guys
Post by wiggy on Aug 21, 2006 19:30:10 GMT 1
have you got the side casing off? this is where the main adjustment on an f2 clutch is locking nut and small screw on the clutch itself set this to as near as poss and then adjust the cable when this is done
Post by mellow on Aug 21, 2006 19:34:40 GMT 1
yup the casings off. i know it says turn till slight pressure then back off quarter of a turn but should the pointer line up with lever untouched or with slack took up when u pull it m8?
Post by wiggy on Aug 22, 2006 18:50:21 GMT 1
Post by mellow on Aug 22, 2006 21:04:37 GMT 1
wow thats amazing ;D thanks wigster
Post by pablo on Aug 22, 2006 21:10:42 GMT 1
i was just about to explain in minute detail then as well...
Post by mellow on Aug 22, 2006 21:11:18 GMT 1
go on then pabs
Post by wiggy on Aug 23, 2006 18:13:54 GMT 1
i was just about to explain in minute detail then as well... really mate...
Post by pablo on Aug 23, 2006 21:15:12 GMT 1
well...theres no need now is there? ;D
Post by mellow on Aug 23, 2006 21:23:27 GMT 1
yep coz i tried wot is suggested
