antos
Post by antos on May 10, 2017 9:39:29 GMT 1
Hi lads, does anyone know if an lc 350 gearchange linkage will fit onto a powervalve f2 please? Cheers antos
Post by oldelsieboy on May 10, 2017 10:14:00 GMT 1
Hi lads, does anyone know if an lc 350 gearchange linkage will fit onto a powervalve f2 please? Cheers antos No. OEB
antos
Post by antos on May 10, 2017 21:51:26 GMT 1
Ok thanks better think of something else then ha
Post by midlifecrisisrd on May 11, 2017 13:05:41 GMT 1
All ypvs gear changes fit
Think the f2 may still be available from Yam
Only the colours were different
antos
Post by antos on May 11, 2017 21:56:03 GMT 1
Many thanks steve it's appreciated mate π Antos
antos
Post by antos on May 13, 2017 10:58:20 GMT 1
Steve it's no longer available from Yamaha mate.
Post by oldelsieboy on May 13, 2017 11:32:32 GMT 1
Post by Yogi on May 13, 2017 11:46:19 GMT 1
You can buy an lc one
Just cut a bit off the back of the peddle mount and use a pv connecting rod from Norbo or MB-designs
Alternatively I've got loads
Matt
Post by stusco on May 13, 2017 12:48:44 GMT 1
Norbo has billet ones
antos
Post by antos on May 13, 2017 13:04:34 GMT 1
You can buy an lc one Just cut a bit off the back of the peddle mount and use a pv connecting rod from Norbo or MB-designs Alternatively I've got loads Matt Thanks mattπ
antos
Post by antos on May 13, 2017 13:05:37 GMT 1
Thanks mateπ I'll try to find them in his shopπ
Post by stusco on May 13, 2017 13:12:09 GMT 1
Ypvs trick bits
antos
Post by antos on May 13, 2017 13:16:25 GMT 1
Just found it thanks, do you know if this would just be a straight swap over, no fowling from that nut on back of the ball?
Post by Yogi on May 13, 2017 18:45:06 GMT 1
Just found it thanks, do you know if this would just be a straight swap over, no fowling from that nut on back of the ball? Yes mate it's a straight swap Got one on my hybrid Matt
antos
Post by antos on May 14, 2017 11:04:45 GMT 1
Cheers mattπ
