Post by hardhatharry on May 8, 2017 23:22:48 GMT 1
Still suffering head gasket failures, I have had my head skimmed but still failing, got annealed copper gasket, has anyone had their barrels skimmed?
Post by 4l04ever on May 9, 2017 8:13:23 GMT 1
Yes, barrels can be out. I had a jig made to get barrels skimmed as a pair. My engineering place has it available and can do the job for you. PM me for contact details.
Post by bare on May 9, 2017 8:16:39 GMT 1
Lose the copper gasket! Those things are more trouble than they are worth. Fit an OEM style one as a start.. Much less aggro involved. Could try tightening the cyl base bolts ..After the cyl head has been torqued.
Post by hardhatharry on May 9, 2017 9:10:05 GMT 1
Im running 2.25 overbore so cant use a standard gasket
Post by 4l04ever on May 9, 2017 9:26:09 GMT 1
You might be able to dremmel the middle out of a standard head gasket to make it big enough. Have done this on a 4L0 engine.
Post by headcoats on May 9, 2017 11:07:30 GMT 1
Didn't know you could go 2.25 bore on a YPVS ? Thought 2.00 was the max ?
Maybe look for some more barrels with a bit of meat left on them ?
Post by midlifecrisisrd on May 9, 2017 11:30:33 GMT 1
Dremel out a genuine gasket.
Base nuts loose, torque head, tighten base nuts
Post by hardhatharry on May 9, 2017 15:05:46 GMT 1
Didn't know you could go 2.25 bore on a YPVS ? Thought 2.00 was the max ? Maybe look for some more barrels with a bit of meat left on them ? No I like my 375cc and the cost of 350 YPVS barrels these days I would get the originals relined instead 2.25, the liners are wafer thin
Post by stusco on May 9, 2017 15:18:14 GMT 1
I just got a pair fresh rebore first oversize £160
Post by hardhatharry on May 9, 2017 17:22:34 GMT 1
I just got a pair fresh rebore first oversize £160 Then add in the cost of pistons and you aren't that far from £400 which is how much I got a set of barrels relined to standard plus pistons and piston kit.
Post by ianr4863 on May 9, 2017 17:32:25 GMT 1
+1 for what Steve midlife said . When I was using a copper head gasket I used a product called Wellseal on it . Worked like a charm for me .
Post by stusco on May 9, 2017 17:37:25 GMT 1
I just got a pair fresh rebore first oversize £160 Then add in the cost of pistons and you aren't that far from £400 which is how much I got a set of barrels relined to standard plus pistons and piston kit. I forgot to say they came with used pistons which have no marks on them but I bought new pistons anyway
Post by hardhatharry on May 9, 2017 21:16:12 GMT 1
hmmm Wellseal looks interesting
Barrels sent off to get a skim, will then use the copper gasket and wellseal when they come back and hope for the best
Post by yamark on May 9, 2017 21:31:30 GMT 1
I use Permatex Copper spray Gasket - It's a high temperature sealant used in conjunction with gaskets. Made in the USA. It fills minor irregularities and effective in sealing non absorbent surfaces. (I'm copying the wording on the tin).
You can get it on Ebay
HTH Mark
Post by 4l04ever on May 9, 2017 22:02:09 GMT 1
Make sure you are getting the barrels skimmed as a pair, as if you do them individually, they may not be perfectly in line with each other when fitted on the crankcases.
Post by hardhatharry on May 10, 2017 15:32:00 GMT 1
The barrels have some slight doming (is that a word) on the barrel surface caused by some dodgy helicoiling being pulled up by tightening the head, the engine chaps are redoing the helicoils and skimming flat so fingers crossed my LC Hybrid will be running again next week.
