Post by grumpyrob on May 5, 2017 13:08:59 GMT 1
Post by steven on May 5, 2017 13:23:30 GMT 1
Hi Rob, If you click on the IMG code at the bottom, it turns yellow and says "copied" you then can put the picture in your post. Cheers, steven.
Post by Bozzy on May 5, 2017 14:17:24 GMT 1
Think pan looks fine but I would be putting the 'YAMAHA' sticker as OE in black at a slant on the pan and a thin black pin stripe (so you can still see the white edges) to the wheel rims
Overall its looks fantastic would love to do the forks and arm conversion..
Post by jon on May 6, 2017 10:14:49 GMT 1
You did ask for opinions, so this is mine. +1 on above. Shape is fine just needs finishing.
I think the upper fairing would look much better trimmed along the bottom.
Post by Shytalk on May 6, 2017 17:49:31 GMT 1
I'm with Jon, the belly pan is fine, the fairing doesn't work for me, it looks like its part of a full fairing (which it is) and stands out because the shape doesn't flow, it would be better looking without the fairing and its framework.
Post by ojay on May 6, 2017 18:51:23 GMT 1
Hey Rob
I have a mint LC2 nose fairing in that colour scheme if you are interested? Also have a mint mounting bracket.
Cheers
Olly
Post by Topman350 on May 6, 2017 19:28:17 GMT 1
Would look better fella with a smaller nose fairing if keeping the belly pan or with a full fairing love that KR scheme though 😉👍👍👍
Post by aid22 on May 6, 2017 22:02:32 GMT 1
Keep the belly pan but not so sure about the fairing.
