Pv motor
Apr 29, 2017 10:41:39 GMT 1
via mobile
Post by lrcarl on Apr 29, 2017 10:41:39 GMT 1
Expected motor to cycle the opposite way Zeeltronic fitted See video Thanks carl
Post by stusco on Apr 29, 2017 10:49:57 GMT 1
The clean cycle is different,so is the setup,sorry I can't remember how it goes but you have too cut the power after it moves once to line up for the 4mm drill and fit and adjust the cables
Pv motor
Apr 29, 2017 11:07:03 GMT 1
via mobile
Post by lrcarl on Apr 29, 2017 11:07:03 GMT 1
Never done a pv before was expecting it to cycle the other way Don't see how cables will reach as is
Post by jackjabba on Apr 29, 2017 11:21:39 GMT 1
wow went to look at the video and got a loud voice saying "I smile at your tits"
Post by stusco on Apr 29, 2017 11:31:32 GMT 1
Never done a pv before was expecting it to cycle the other way Don't see how cables will reach as is They won't you will have to power off when it first stops then connect the cables saying that your setup isn't standard
Pv motor
Apr 30, 2017 8:14:10 GMT 1
via mobile
Post by lrcarl on Apr 30, 2017 8:14:10 GMT 1
Not standard set up (twin pulleys) But same set up as standard with zeel for cycle Carl
