Post by steven on Apr 24, 2017 19:22:27 GMT 1
Hi, Had a major Do'h ! moment tonight. If anyone has seen any of the pics I have posted of my 4L0 you will know it has a Micron fork brace on it. I put this LC on the road in 2013, with new dust seals. Since then I have replaced the dust seals in 2014, 2016 and now they need done again, as I can see slight splits starting once more in the dust seals. Tonight I messaged Norbo to see if he had any of the fork dust seals in stock, that go over the top of the forks, as mine keep splitting every two years or so. I presumed it was just a thing with Micron fork braces, as the dust seals do go on, but are very tight over the top of the fork brace. I found this pic on the forum that list,s all the numbers for Micron fork braces. As you can see, the correct number for a 4L1/4L0 is 71.76.-54G The fork brace I have on mine is numbers 71.76.-58G, so is for an RD350 YPVS ( which I think is an LC 2) ?? It fits ok, but there are nylon spacers/expanders that go round the fork legs, I thought they were part of the fork brace, as they are very well made, but someone must have made them up, as this fork brace was on an LC I bought years ago. I havnt looked yet, but are Micron fork braces still available ? Mabey I could buy the correct clamps, as the top plate is the same number for the LC,s and YPVS,s, or does (long shot) anyone have a set of 54G clamps for sale ? or want to swap them for a set of 58G clamps. Thanks in advance, Hommer Simpson !
Post by bare on Apr 24, 2017 19:31:28 GMT 1
Going to have to decide which is more important to you. Affectation Fork braces or Replacing dust seals. Which normally are good for decades
Post by steven on Apr 24, 2017 22:34:39 GMT 1
Hi Bare, Thanks for the reply. I do like the Micron one, but it is obviousely not the correct one for my bike, but once it is on you would never know, and I do think it looks the part. In saying that, I have read that they dont really do much, as the forks flex elsewhere. Its no major hastle stripping the forks off it every two years or so, and its a good excuse to get in and give all the stripped off components a check, "deep clean" and a polish etc. I went and dug out my other fork brace tonight, its a bit skanky, but is all there and the threads etc are all good, so I may just end up tarting that one up and using it, as I have tried it on a set of 4L1/4L0 forks and it fits perfectly. I may well just end up placing the Micron one in my YPVS parts heap ! Im not sure what kind my other/spare one is, is it one of the Telefix ones ? There is no writing or anything on it, appart from the numbers B1 on the underside, and a 1 and 2 to mate up the two clamp halfs. Thanks in advance if anyone can identify what type it is. Cheers, steven.
Post by 4l04ever on Apr 24, 2017 22:40:30 GMT 1
Yes, it looks like a Telefix one. Had one on my old 750 turbo.....
Post by 4l04ever on Apr 24, 2017 22:41:09 GMT 1
...and yes, the 58G is for LC2 31K forks. Not for F1/F2/N1/N2/R
Post by steven on Apr 24, 2017 22:46:46 GMT 1
Hi 4L0, Thanks for the info...... do the two lateral adjusting cap screws face to the front or the back when fitted ? I havnt looked into that yet either. cheers. steven.
Post by veg on Apr 24, 2017 22:48:20 GMT 1
If you decide to sell the lc2 one let me know be interested Thanks
Post by 4l04ever on Apr 24, 2017 22:48:37 GMT 1
Not sure, as mine was off when I got the bike. Just in the spares box. Probably neater at the back....
Post by veg on Apr 24, 2017 22:53:25 GMT 1
From memory the back
Post by Yogi on Apr 24, 2017 22:59:46 GMT 1
It is a telefix I've got an lc2 one hanging up As for the adjuster bolts I don't think it matters, your call if you wanna see the bolts or not
Matt
Post by steven on Apr 24, 2017 23:04:00 GMT 1
...Ok, thanks for the info 4L0 and Veg. I,ll let you know if Im getting rid of the Micron one Veg, I have a fair few YPVS bit I was planning on getting together and selling to fund another 4L1/4L0 restoration, as the LC I have on the road at the moment had a 31K engine, pipes, clox etc etc on it when I bought it. Thanks again. steven.
Post by steven on Apr 24, 2017 23:06:04 GMT 1
It is a telefix I've got an lc2 one hanging up As for the adjuster bolts I don't think it matters, your call if you wanna see the bolts or not Matt Ok, Thanks Matt, cheers.
Post by veg on Apr 25, 2017 7:51:47 GMT 1
No probs matey. Thanks
Post by steven on May 7, 2017 20:21:31 GMT 1
Hi, I found an antique can of paint stripper the other day at work in a building that was getting cleared out. It was going in the skip, so I thought I would give it a go on my Telefix fork brace. I was hoping that as it was old, it would be "proper" paint stripper and not the guff you get nowadays. I am pleased to report that it was indeed "proper" paint stripper like you used to get. The Telefix brace is coated with a kind of crinkle type finish and the old paint stripper started to work immediately, you could even see the wavy lines/vapour coming out the tin. My glove melted in no time ! It did the job just fine. Not sure wheather to polish up the Telefix one or paint it black again. Cheers, steven.
Post by midlifecrisisrd on May 7, 2017 20:31:42 GMT 1
Micron no longer in business so a new one is not an option.
You do get modern copies, norbo does them as well as on ebay. Think it is fastec that make them
Got one for my lc2 and where it said micron it says YPVS
Think you get the option of RD LC or a tuning fork
Post by steven on May 8, 2017 8:19:25 GMT 1
Hi Steve, Thanks for the info, Cheers, steven.
Post by steven on May 8, 2017 8:31:46 GMT 1
....just had a thought after my night shift, so may not be thinking clearly !
Im not too well read on YPVS stuff, my only experience with YPVS,s was a 4L0 I had on the road for a year with a 31K engine in it. LC forks are 32mm o/d, what size are LC2 forks, I know some of the YPVS forks are bigger, but not too sure of the sizes. Im thinking mabey I could get LC2 dust seals ? as they would go over the LC2 fork brace ? Does anyone have a pic of LC2 fork dust seals please ? Thank you and goodnight, im off to bed. steven.
Post by Yogi on May 8, 2017 8:37:02 GMT 1
Hi Steve Lc2 forks are 35mm Matt
Post by steven on May 8, 2017 8:41:42 GMT 1
... hello Matt, oh well, thats that idea binned, serves me right for thinking about something so importaint after being awake for almost 24 hours ! Thanks for posting the pic. Cheers, steven.
Post by Yogi on May 8, 2017 8:43:35 GMT 1
... hello Matt, oh well, thats that idea binned, serves me right for thinking about something so importaint after being awake for almost 24 hours ! Thanks for posting the pic. Cheers, steven. All part of Rds mate I've got a shed full of binned ideas Matt
Post by verbotten on May 25, 2017 13:02:50 GMT 1
Post by verbotten on May 29, 2017 9:25:01 GMT 1
Post by steven on May 30, 2017 18:15:24 GMT 1
Hi Verbotten, Thanks very much for posting the Telefix leaflet. Where in Ayrshire are you ? Im no far fae Killie. Thanks again. steven.
Post by verbotten on May 31, 2017 7:47:40 GMT 1
Hi Verbotten, Thanks very much for posting the Telefix leaflet. Where in Ayrshire are you ? Im no far fae Killie. Thanks again. steven. Very welcome, I live in the sunny capital of Ayrshire...Ayr
Post by steven on May 31, 2017 10:19:23 GMT 1
...ah right, here is my mars bar LC at Ayr harbour. Do you know Brian ? (BA) from Ayr. Brians 3 stripe white LC won its class at Ayr Classic bike show a couple or so years ago. steven.
Post by verbotten on May 31, 2017 11:07:47 GMT 1
Hi Steven - PM sent
Post by gci_scot on May 31, 2017 20:29:36 GMT 1
Hi Verbotten, Thanks very much for posting the Telefix leaflet. Where in Ayrshire are you ? Im no far fae Killie. Thanks again. steven. Very welcome, I live in the sunny capital of Ayrshire...Ayr Good to see the lc's still around in Ayrshire. I lived in Dundonald when I had my first lc, in 1987.
Post by steven on Jun 1, 2017 8:36:36 GMT 1
Hi Gci, I do like a run to the top of Dundonald Hill, great view from up there on a nice day.
Post by muttsnuts on Jun 1, 2017 15:06:55 GMT 1
its your lucky day, I have some 54G clamps and wouldn't mind some 58G clamps for my track bike, pm me if interested in doing a swap
Post by steven on Jun 1, 2017 16:20:11 GMT 1
Hi Dave, Yes please, I am very interested. PM sent. Thanks very much. steven.
