Post by kostas on Apr 12, 2017 21:23:18 GMT 1
Just went up to 1.5 oversize on my YPVS engine. It is all standard.
do I need to trim the head gasket to avoid the piston hitting it?
Post by reedpete on Apr 12, 2017 22:04:51 GMT 1
Sorry if this reply sound obvious ....but not if the piston will pass through it! Std. OE gaskets have probably enough clearance as they also need to allow for alignment tolerances but if it's a copper one then just check it.
Post by reedpete on Apr 12, 2017 22:05:01 GMT 1
Post by reedpete on Apr 12, 2017 22:09:24 GMT 1
Have no idea how that managed to double post....and can't see where to delete either! Perhapps some kind person would come along and tidy up!
Post by muttsnuts on Apr 13, 2017 13:19:40 GMT 1
as well as checking the head gasket, check the power valves aren't catching the rings as at 1.5mm O/S your right on the limit where they can and sometimes do catch, if they do then you need to trim the power valves very slightly
Deleting your second post: look at right hand top corner and click on the down arrow next to the picture of a cog, you will find delete there
HTH
Post by kostas on Apr 13, 2017 15:22:42 GMT 1
PVs clear the rings. Head gasket is marginal so I will take the dremel out and sort it.
Thanks
