antos
Post by antos on Apr 12, 2017 9:30:39 GMT 1
Guys I've searched 5 pages of indicator problems and can't find an answer , can anyone help, all my indicators worked fine before my restore, so fitted new indicators from norbo wouldn't flash so put the correct 21 watt bulbs in them and they flashed 👍 Next day tried them no flash, they now only flash when I hold the left handlebar switch against it's stop? Any ideas guys
Post by shaunthe2nd on Apr 12, 2017 10:01:26 GMT 1
Sounds like the mechanism in the switch has jammed or the contact worn/broken. Take the it apart and give it a good clean and replace. I had a problem with one and was fine after a good clean up.
antos
Post by antos on Apr 12, 2017 10:10:57 GMT 1
Cheers Shaun, I cleaned everything on the strip down and sprayed inside with gt85, but yes it makes you think it's the problem as holding it on they work.
