antos
Post by antos on Apr 12, 2017 9:07:46 GMT 1
Guys any tips on best and quickest way to polish up the ypvs lettering on cylinder head after it's been sprayed black? Thanks
Post by crazydave on Apr 12, 2017 12:45:38 GMT 1
Wet & dry paper and sanding board/block. Always keep paper wet. Have a bucket with water and small amount of detergent mixed in close by.
I would start with 180-240 grit to remove top layers of paint.
Once the bare aluminium starts showing move up to 320 grit until all aluminium is exposed.
Then use 400,800,then 1200 for a nice finish. You could use 2000 grit for a mirror finish, but in my opinion, it wouldn't look right that shiny.
Rinse paper in bucket regularly. Depending on desired finish either rub backward and forward, or use circular/figure 8 movement.
antos
Post by antos on Apr 12, 2017 22:41:17 GMT 1
Thanks very much Dave I appreciate thatπ Will do exactly that π
Post by Yogi on Apr 13, 2017 5:13:15 GMT 1
For future reference
What I do is polish it before spraying Then it's easier to get back once sprayed
Matt
antos
Post by antos on Apr 13, 2017 10:21:03 GMT 1
Damn it I never even thought of that mattπ I did as you suggested on the wheel rims before I sprayed them, so I know that's the right way .doh π
