Post by petehodges on Apr 10, 2017 9:37:48 GMT 1
morning lads after a day off fooking about with my rear brake i,m now getting somewhere near so i though had a look this moring & where they bolt to caliper there weeping slightly so i need some more copper washers could some please tell me the size i,m after & where to get them as dont really want to strip mine off yet to measure them , ive seen loads on ebay just dont want to buy wrong ones as i think i need the thin washers thanks pete
Post by 4l04ever on Apr 10, 2017 9:42:25 GMT 1
I think most are M10 bolts, so 10mm ID washers :-)
Post by LC_BOTT on Apr 10, 2017 9:46:31 GMT 1
Under the impression, all the bolts are the same size, and it's just the pitch that alters from manufacturers. Thought they were M10.....Can't you just anneal them, or are they badly squashed or distorted?
Post by petehodges on Apr 10, 2017 10:02:12 GMT 1
Under the impression, all the bolts are the same size, and it's just the pitch that alters from manufacturers. Thought they were M10.....Can't you just anneal them, or are they badly squashed or distorted? ive had a mare with the rear brake so would rather just put new ones on i,m also going to put some ptfe tape on threads thanks
Post by LC_BOTT on Apr 10, 2017 10:27:29 GMT 1
If the washers are sealing there should be no need for PTFE tape. Wouldn't use it myself, except on toilets
Post by midlifecrisisrd on Apr 10, 2017 10:58:21 GMT 1
Are you using a genuine bleed nipple
A lot of pattern ones don't seat right so the let little bubbles in causing your type of problems
Post by Ozhammer on Apr 10, 2017 11:06:24 GMT 1
Are you using a genuine bleed nipple A lot of pattern ones don't seat right so the let little bubbles in causing your type of problems Steve +1 for dodgy bleed nipples, took me bloody ages to diss that too! 😳 Rgds Ozhammer
Post by Ozhammer on Apr 10, 2017 11:07:09 GMT 1
suss - bloody predictive text! 😡
Post by davey on Apr 10, 2017 12:14:45 GMT 1
Heat the washers to cherry ted , then dump em in cold water , this will soften them enough to reuse
Post by reedpete on Apr 10, 2017 20:15:52 GMT 1
They do need to be torqued up too... Helped someone the other day who has fluid pissing out everywhere and was distraught. He couldn't stop it whatever he tried...Anyway I checked the torque...they were 'loose tight', so I went up one setting to 'tight tight' 😀😀😀 problem solved. They were new washers btw.
Post by bare on Apr 10, 2017 20:24:54 GMT 1
No.. I believe annealing is heating then letting the metal cool all by itself. Quenching is for hardening.. is it not?
Post by stusco on Apr 10, 2017 20:30:57 GMT 1
No.. I believe annealing is heating then letting the metal cool all by itself. Quenching is for hardening.. is it not? Nope it's heating until cherry red then quenching makes then nice and soft
Post by stusco on Apr 10, 2017 20:34:55 GMT 1
They do need to be torqued up too... Helped someone the other day who has fluid pissing out everywhere and was distraught. He couldn't stop it whatever he tried...Anyway I checked the torque...they were 'loose tight', so I went up one setting to 'tight tight' 😀😀😀 problem solved. They were new washers btw. They probably needed annealed
Post by reedpete on Apr 10, 2017 20:40:09 GMT 1
Possibly, but as I said they were new so should have been good to go. Thing is M10 can take some torque, don't be frightened! Just looking to try find what they should be done too but can't find my list for the mo.
Post by reedpete on Apr 10, 2017 20:44:02 GMT 1
No.. I believe annealing is heating then letting the metal cool all by itself. Quenching is for hardening.. is it not? Different metals behave differenty. Copper is annealed just by the heating. After that it doesn't matter how you cool. Fast or slow it's the same. Steel alloys are different, fast cooling can 'freeze' the small crystaline structure and stops them from formering the larger crystalline structure which has different properties.
Post by petehodges on Apr 10, 2017 21:11:58 GMT 1
Are you using a genuine bleed nipple A lot of pattern ones don't seat right so the let little bubbles in causing your type of problems Steve steve mine are lockheeds so i think diffrent nipples to lcs mate
Post by rich on Apr 10, 2017 21:37:32 GMT 1
Jeez, not even worth the effort of annealing. Just pop into your local car accessory shop and grab a pack of new ones, they aren't expensive! 10mm id standard copper sealing washers.
Post by Tobyjugs on Apr 10, 2017 22:25:38 GMT 1
If i have a choice i would prefer to use ally washers over copper as they seem to work better.
Post by Deleted on Apr 11, 2017 12:22:10 GMT 1
Ok if you are sure your bolt has a M10 diameter then all youneed is an outside diam that just fits under the head of the bolt
so M10 x 12 or 14mm should do
both are standard sizes, btw you need to buy fuel washers not plumbing washers which are not thick enough
