Post by downerhouse on Apr 2, 2017 16:16:38 GMT 1
Single key conversion for YPVS.
Thought some of you might like to know this. I've just spent a few hours converting my multi key 31K YPVS to single key.
I took a gamble and ordered a new old stock 4L0 key set off eBay. Not cheap at around£180.
The fuel cap fits straight on.
The seat latch needs taking off and is very easy to dismantle and swap the old / new lock cylinders over. If you can't be bothered to do that that 4LO catch bolts straight on but the helmet hook and seat catch are slightly smaller.
The ignition was a little trickier. I cut the new 4L0 wires and soldered on the cable from the original 31k lock. Same colours, you just need to take care of the 2 black wires - the 4L0 block is 6 wire and 31K 5 wire with a separate black bullet for the 6th. Pretty easy really if you take your time.
As an added bonus I also got a working steering lock as my bike was a Belgium import which originally had a frame steering lock - so I had the frame modded to accept a uk steering lock.
Hope that helps. Steve
Post by Yogi on Apr 2, 2017 16:48:55 GMT 1
Nice work All I did for my German n1 was buy a lock set off Norbo for £135 Take the bottom off your old ignition plus the brass ring and swap them Then swapped the seat lock barrel an jobs a good un
Maybe I had a different set up than you though
Matt
Post by downerhouse on Apr 2, 2017 16:55:36 GMT 1
I tried various combinations of taking the bottom off, and brass ring etc. But when the ignition was switched to steering lock, the power would come back on. So after a few hours of faffing decided the solder method would be quickest.
Post by Yogi on Apr 2, 2017 16:58:29 GMT 1
I might of just got lucky with mine
Forgot to mention the pv latch also fits straight in the 4lo lock
Happy days all round
Matt
Post by midlifecrisisrd on Apr 2, 2017 17:18:58 GMT 1
I just send my multi key set to Simon wells and get him to convert the cylinders to one key for about 30 quid
Post by downerhouse on Apr 2, 2017 17:27:15 GMT 1
Doesn't work if you don't have Yamaha keys / locks to start with.
Post by 4ce on Apr 2, 2017 20:30:06 GMT 1
mine did, pattern ignition, and filler cap yamaha seat and helmet lock. Simon matched them all to the filler key.
