antos
Post by antos on Mar 29, 2017 23:15:19 GMT 1
Guys if there's not much flats on the ends of inner valves where the joiner goes are they goosed? Before I took the joiner out it was wobbling up and down a fair bit, the ends a pretty rounded π Best place to buy them? Thanks
Post by dusty350 on Mar 30, 2017 8:43:01 GMT 1
antos
Post by antos on Mar 30, 2017 8:45:09 GMT 1
Many thanks π Turning into a money pit ha
antos
Post by antos on Mar 30, 2017 9:31:37 GMT 1
Well Β£190 from them dusty is better than Β£280 Yamaha one eBay π³ So the m b design ones would just swap over dusty with no probs yea? I'm getting the barrels rebored too. Thanks antos
Post by Shytalk on Mar 30, 2017 10:29:36 GMT 1
So the m b design ones would just swap over dusty with no probs yea? Yes they are a straightforward swap, you might have to specify whether you want them for a 31K engine or a 1UA looking at the advert otherwise no issues.π
Post by dusty350 on Mar 30, 2017 10:56:47 GMT 1
+1 Just let Martin know which engine you have as the pv's differ slightly. He is a great fella to deal with so you'll have no issues. Have a close look at your pv joining piece too, they wear and get sloppy - often before the ends of the valves do so you may end up changing that too. Dusty
antos
Post by antos on Mar 30, 2017 12:02:27 GMT 1
Many thanks dustyπ Yea centre piece is gone as well . It's another couple of hundred I hadn't budgeted for but hey ho it is what it is . Thanks for your help mateπ Antos
Post by Deleted on Mar 30, 2017 12:24:01 GMT 1
I got mine from Fast From The Past, one hiccup is that the LH outer end wasn't threaded, a tap took care of that though
$99US for the pair plus postage
Again you need to choose from 31K or 1UA
antos
Post by antos on Mar 30, 2017 16:37:58 GMT 1
Thanks for that mateπ
Post by stusco on Mar 30, 2017 17:09:46 GMT 1
I got mine from Fast From The Past, one hiccup is that the LH outer end wasn't threaded, a tap took care of that though $99US for the pair plus postage Again you need to choose from 31K or 1UA Any feedback are they any good
Post by Deleted on Mar 31, 2017 3:41:02 GMT 1
Hi Stusco
They've been in for 2.5 years now and 5000km no problems so far
It was probably a once off where I had to tap the pulley side to attach the PV pulley, no big deal, just initially could figure why the pulley screw wouldn't go in
Post by stusco on Mar 31, 2017 7:51:09 GMT 1
Looks like a bargain at that price all you need is bushes pity they don't sell them
Post by Deleted on Mar 31, 2017 15:13:04 GMT 1
Luckily I was able to reuse the bushes I had
There are no leaks from either side
Certainly if the new rebuild allows I will use the PV's that came with that otherwise I will get them from FFTP again
Post by bare on Mar 31, 2017 17:24:11 GMT 1
Couple of thoughts.. I got Billet PV valves years ago.. via the infamous Australian shyster.. albeit with a Year! delivery time. Asked for the 1UA valves cuz they claimed as profiled for the slightly different 1ua exhaust. Welll.. I had to put in over an hour .. each .. grinding/reshaping them.. to fit properly ie unobstructive of the exhaust gass path So much for their skillful design Also the PV's bearing shaft sizes were off (varying size!).. Grrr. On Brand New Yama supplied Bushes. When questioned the Twit claimed it was purpose done for heat reasons. Bollocks imo :-) I then Sleeved the (new) PV shafts to suit my brand new oem bushes. Been running 'perfectly' for years. Hopefully weird wicked's bits are better made.
Post by wreckrat on Dec 3, 2018 21:39:37 GMT 1
I got mine from Fast From The Past, one hiccup is that the LH outer end wasn't threaded, a tap took care of that though $99US for the pair plus postage Again you need to choose from 31K or 1UA Evening, where would I find 'far from the past regarding the power valves....had a quick look but no joy cheers A
Post by Deleted on Dec 4, 2018 11:40:32 GMT 1
fastfromtheapst.com
Just looked and they are definitely still on the website under Yamaha parts, RZ350
Post by urbantangleweed on Dec 4, 2018 17:54:06 GMT 1
Post by wreckrat on Jan 13, 2019 21:37:57 GMT 1
A bit late in the day but I can recommend the PV's from FFTP, swift delivery and work a treat....very happy.
