Post by allspeeds on Mar 25, 2017 15:22:58 GMT 1
i am just about to put the carbs back on my f2 ,where does the 2nd fuel line on the tap, the smaller one go to? Yeah I know I,m thick but I have never done one before it was already stripped down before I saw it.
Post by jessy03 on Mar 25, 2017 17:22:25 GMT 1
Inner right hand carb Jess
Post by Yogi on Mar 25, 2017 18:48:02 GMT 1
The vacuum pipe on the inside of the right carb operates the diaphragm in the petrol tap You need a pipe from the tap to the smaller spigot below the balance pipe
You've probably sorted it by now but I thought I'd mention it anyway
Matt
Post by allspeeds on Mar 25, 2017 19:00:06 GMT 1
Thanks Jess and Matt Now found where it goes, I can see why I was confused as the brass spigot is missing where it the vacuum pipe joins the carb. Plus i put my glasses on! Where can i get the brass spigot from and what is the diameter for the vacuum pipe? Thanks again this has been doing my head in.
Post by Yogi on Mar 25, 2017 20:06:03 GMT 1
If all else fails blank it at the carb and tap and use it on prime That's how the older carbs were Norbo does the pipe but not sure about the brass spigot Matt
