Post by nedster on Mar 21, 2017 21:36:10 GMT 1
Hi does anyone know what is the best way to remove and replace the exhaust mounting bushes that are in the footrest hangers. I was hoping to do it myself but do I need it done profesionally?
Post by Mr Kipling on Mar 21, 2017 21:52:48 GMT 1
get em pressed out , same when refitting.. take the new ones along at same time 5 min job.. if wanna do urself use dremmel to carefully cut the outer race of the bush that,s in the footrest ..
Post by midlifecrisisrd on Mar 21, 2017 21:58:38 GMT 1
Rip the centre out then cut a slot in the outer with a hacksaw
I press the new one in with a socket and a vice
Post by bare on Mar 22, 2017 3:36:58 GMT 1
oops
Post by Deleted on Mar 22, 2017 11:33:21 GMT 1
I pushed my old ones out with a socket, nut, a couple of big washers and an 8mm set screw
Came out easily as did the new ones too
Post by tony1964 on Mar 22, 2017 11:59:55 GMT 1
knocked mine out using a socket with the same outer diameter as the bush, put the replacement ones in the same way.
