Post by petehodges on Mar 20, 2017 23:12:40 GMT 1
Evening lads Be refitting rear tail back on Lc tonight & Gaps are not good one side is tight & other is really gappy can fit fingers under seat at back I think something may be out line any ideas please What are your bikes like ?any pics
Post by marsbar350 on Mar 20, 2017 23:51:16 GMT 1
has the left hand seat catch clicked?
Post by petehodges on Mar 20, 2017 23:59:05 GMT 1
has the left hand seat catch clicked? Yes mate I made sure they were both down
Post by marsbar350 on Mar 21, 2017 0:17:33 GMT 1
sub frame got a slight twist in it
Post by steve h on Mar 21, 2017 0:24:02 GMT 1
Is the seat twisted at all? Should be easy enough to work out if sub frame is dicky.
Post by JonW on Mar 21, 2017 0:48:46 GMT 1
when on center stand (or paddock stand) how does the subframe and seat look from the back? you should be able to see any twist by uneven indicators or other parts i would think.
Post by 4l04ever on Mar 21, 2017 9:05:46 GMT 1
You can have one worn seat catch too, so it would not pull the seat down as much on that side. Try just pushing the seat down and see if it looks even while being held down. If so, it could be the catches...
Post by 4l04ever on Mar 21, 2017 9:07:25 GMT 1
Also, try another seat to see if it is just this one.
Post by veg on Mar 21, 2017 9:13:50 GMT 1
Is it a genuine guiliari seat? I only ask because I am sure I read that the converted ones sometimes get pulled up at the back? Due to how they are made. Could be wrong mind.
Post by veg on Mar 21, 2017 9:15:43 GMT 1
Is it a new seat? Did you have any problems with an old seat? Have you rebuilt it? Just trying a process of elimination. Bloody hate it when stuff plays with your head. Hope you get it sorted
Post by midlifecrisisrd on Mar 21, 2017 9:18:19 GMT 1
As veg says it may be too much tension on the seat cover bending the base
Can't be seat catches to get a finger in. Has to be way out for that
Post by petehodges on Mar 21, 2017 11:18:38 GMT 1
Is it a genuine guiliari seat? I only ask because I am sure I read that the converted ones sometimes get pulled up at the back? Due to how they are made. Could be wrong mind. Yes veg I'm sure it's genuine seat it was white but had a black cover put on it I've not got another seat too try but I think it's more than that mate
Post by petehodges on Mar 21, 2017 11:21:16 GMT 1
Thanks for your ideas 💡 lads when I get time next week I'm going to strip it all off again as I think something out if you look at the bike from the back one side is clearly higher than other is it just a case of moving (bending) the subframe about ?
Post by steve h on Mar 21, 2017 14:45:00 GMT 1
Hopefully you should be able to tweak it back. These bikes were never the preserve of "careful" riders and I'll bet 90% of them have visited the tarmac rubberside up! So it's not unusual for summat to be little out. Which is why after buying something to restore, visiting a motoliner could be a wise move.
Post by stusco on Mar 21, 2017 16:42:24 GMT 1
My seat is a poor fit as well ,copy seat👎
Post by oldelsieboy on Mar 21, 2017 18:03:21 GMT 1
As veg says it may be too much tension on the seat cover bending the base Steve If the seat cover was fitted by a gorilla the base can bend resulting in a poor fitting seat. OEB
Post by steve h on Mar 21, 2017 18:14:18 GMT 1
Poor fitting seat.......You are being far to generous OEB.
Post by petehodges on Mar 22, 2017 9:02:04 GMT 1
As veg says it may be too much tension on the seat cover bending the base Steve If the seat cover was fitted by a gorilla the base can bend resulting in a poor fitting seat. OEB Mines not far off that Nigel ☹️
Post by dusty350 on Mar 22, 2017 9:28:58 GMT 1
Hi Pete Can you post the rear light pic up that you sent me ? I think your subframe may be twisted, presuming everything was bolted up when you took the pic. If you thought a seat catch was worn, you could put some washers between the top of the catch and the underside of the bracket it bolts to, to lower the catch and see if it lines up, but I think it may be more than that.
Dusty
Post by oldelsieboy on Mar 22, 2017 18:24:48 GMT 1
If the seat cover was fitted by a gorilla the base can bend resulting in a poor fitting seat. OEB Mines not far off that Nigel ☹️ Maybe it was the same gorilla that covered you seat as mine. OEB
Post by petehodges on Mar 26, 2017 21:13:15 GMT 1
Hi Pete Can you post the rear light pic up that you sent me ? I think your subframe may be twisted, presuming everything was bolted up when you took the pic. If you thought a seat catch was worn, you could put some washers between the top of the catch and the underside of the bracket it bolts to, to lower the catch and see if it lines up, but I think it may be more than that. Dusty Hi dusty Sorry mate been away for a few days on bike I'll get some pics up tomorrow mate
Post by dusty350 on Mar 27, 2017 7:42:31 GMT 1
No worry mate Just that the pic you sent me made me think there was a (possible) subframe problem, and I think it's worth posting it for others to see and offer opinions. Dusty
webbo
Post by webbo on Mar 27, 2017 22:07:12 GMT 1
Hi I had a similar problem when I finished my 350. Turned out to be a twisted subframe. Easily fixed with a scaff tube and protection on the frame. Cheers
Post by Tobyjugs on Mar 27, 2017 22:19:56 GMT 1
Just done the same with the bike Kees crashed. I also lifted the back up a little whilst the subframe was hand tight. Next job the rest of the frame.
Post by petehodges on Mar 28, 2017 21:54:46 GMT 1
Hi I had a similar problem when I finished my 350. Turned out to be a twisted subframe. Easily fixed with a scaff tube and protection on the frame. Cheers webbo i take you twisted back with the subframe bolted on i,m going too try sort this out tomorrow as its doing my nut in
Post by petehodges on Mar 28, 2017 21:58:20 GMT 1
No worry mate Just that the pic you sent me made me think there was a (possible) subframe problem, and I think it's worth posting it for others to see and offer opinions. Dusty Here you mate
Post by JonW on Mar 28, 2017 23:31:09 GMT 1
OMFG! Absolutely thats got to be a bent subframe, and maybe also the rear spars too?
If you strip those parts all off and stand it on its center stand, and measure down to the ground, are the side the same length to the ground? If they are, then fit another subframe and see what thats like as it looks miles out.
Post by jon on Mar 29, 2017 8:13:27 GMT 1
Two words: Dry Build.
This sort of thing has caught my mate out twice.
I always dry build as it's easier to sort out before paint.
webbo
Post by webbo on Mar 29, 2017 13:05:30 GMT 1
Hi I had a similar problem when I finished my 350. Turned out to be a twisted subframe. Easily fixed with a scaff tube and protection on the frame. Cheers webbo i take you twisted back with the subframe bolted on i,m going too try sort this out tomorrow as its doing my nut in Yes, I just removed seat, painted bits and protected the frame with bits of rubber where the scaff pole touched. I got 2 other people to steady the bike and bend it a bit at a time measuring as you go. It all seems like a nightmare but once you get dtuck in it's all part of the build. Good luck
