Post by dangerousal on Mar 19, 2017 21:42:26 GMT 1
Hi Guys,
I have finally got around to starting my build...the front end will be a zxr 400 usd conversion and I am looking for information on what is involved in pressing the steering stem out of the ypvs triple tree.
I know the stem is welded to the yolk, but i am wondering how much material needs to be removed from the underside of the yolk to clear the weld...
Alternativelty does anyone have a pressed out stem the want to sell, or is able to do it for me, I'm in Poole Dorset.
Post by dllc on Mar 20, 2017 18:17:22 GMT 1
a little bit more to it than what you think. as well as changing the stem you will need a spacer to go between the top of the stem and the zxr top yoke, Nigel in NK racing did mine for me.
Post by dangerousal on Mar 20, 2017 19:59:43 GMT 1
Sure I am aware of the spacer.....do you know if the stems are the same diameter...how much did nk charge?
Post by dllc on Mar 20, 2017 20:12:45 GMT 1
pv stem is narrower. hence the need for spacer for top yoke. cant remember how much it cost. was getting a few bits modded at the time.
Post by jon on Mar 22, 2017 8:37:52 GMT 1
Sounds like a simple top hat spacer to reduce the diameter. Shouldn't be more than £25 I'd have guessed?
Post by dangerousal on Apr 3, 2017 20:12:39 GMT 1
removed stem from ypvs yolk, and machined down slightly, machine out zxr stem bore slightly to fit ypvs stem, parted off zxr stem above the yolk and milled down flush, pressed ypvs stem into zxr stem bore, and will weld ypvs stem to zxr stem....made top hat spacer for top yolk, new ball race bearings fitted, modded zxr yolk to extend lock stops to engage with ypvs stop tab on frame...anyone see any issues with this approach?
Post by Kryten on May 1, 2017 19:43:14 GMT 1
Can you post a few pics of the top hat spacer and top yoke,i dont have this fitted on my conversion. Im a little puzzled as i dont need one fitting.
Post by dangerousal on May 31, 2017 13:15:06 GMT 1
Top hat spacer I made Is essentially a Bush to increase the diameter of the ypvs steering stem to fit the diameter of the zxr top yolk..
