Post by saigonmark on Mar 11, 2017 19:34:06 GMT 1
I have a loose wire under the left side panel, does anyone know what it's for and where it should go? Why would it be disconnected?
Post by oldelsieboy on Mar 11, 2017 19:43:18 GMT 1
I have a loose wire under the left side panel, does anyone know what it's for and where it should go? Why would it be disconnected? German spec 4L0/1's are not fitted with self cancelling indicators hence the yellow green wire from the relay is connected to the black wire from the loom. On UK spec machines the yellow/green wire from the relay is connected to the yellow/green wire from the loom completing the self cancelling circuit. OEB
Post by saigonmark on Mar 11, 2017 21:13:31 GMT 1
Thanks for the reply. Can I just change relay for a UK self cancelling unit and then plug the yellow/green wire into the yellow/green loom connector to get self cancelling indicators?
