Post by allspeeds on Mar 8, 2017 22:00:44 GMT 1
Hi Whats the differences between a German 80lc and a 125lc, are they a 125 with an 80 engine dropped in or is there any other differences? Thanks
Post by museumman on Mar 8, 2017 22:37:32 GMT 1
You mean the German 80LC MK2 ?
Exhaust and carb obviously
Swing arm is different Rear shock has different part number, possibly to suit lighter riders? (aged 16 in Germany) Frame slightly different for engine mounts All electrics are different, main loom, inc switch gear (also clutch perch iirc) Air box rubbers narrower Different battery box Speedo Right footpeg holder/exhaust mount Front disc is slotted Right footpeg isn't sprung (stays up for kick starter)
Post by allspeeds on Mar 8, 2017 22:52:50 GMT 1
Hi Museumman Whats the difference between Mk1& Mk2? Thanks
Post by museumman on Mar 9, 2017 9:18:06 GMT 1
The MK1 is smaller /moped size and the only RD80LC known to most of the world. In Germany the 80cc's were very popular, so for whatever reason Yamaha turned the RD125 and DT125 into 80's. They are more common than the actual 125s in Germany.
Post by sandpiper on Mar 9, 2017 9:52:47 GMT 1
Hi all speed I have both uk and German both completely different bikes if you want to take a look give me a PM
Post by allspeeds on Mar 9, 2017 20:56:36 GMT 1
Hi i got it straight now a guy showed me an uk 80 lc as i remember them he also had a german 80 that is the same as the 125 i bought it off him in boxes as it was a basket case and very cheap ,its got no motor so i make a mk1 125 out of it.its a 30w frame.
