Post by neo on Mar 5, 2017 21:39:00 GMT 1
Hi all I'm after some help, I have an f2 I am going to put on a 31k top yoke and some bars a) I hope all the loom and controls have long enough cables ... I can see the front braided hoses will not be.. the hose from the master cylinder goes to the front right calliper (sitting on the bike) off of that hose is a joiner for another hose which comes off to the left calliper my questions are
A) should I have a hose splitter on the front B) if I get a replacement hose kit for the front from say hel or Goodrich front brake kit will it be for the bike if it had a splitter C) could I get a longer hose to the right caliper then one from that calliper off the banjo over the top of the mudguard to the left calliper
I have not explained this to well have I 😬
Thanks in advance
Post by Shytalk on Mar 6, 2017 5:02:19 GMT 1
There should be a splitter bolted to the bottom yoke, I have got a 3 line set of hoses, can't remember if they're HEL or something else and I have a splitter if you don't have one, that would solve your problems 😄👍
Post by neo on Mar 6, 2017 7:46:48 GMT 1
There should be a splitter bolted to the bottom yoke, I have got a 3 line set of hoses, can't remember if they're HEL or something else and I have a splitter if you don't have one, that would solve your problems 😄👍 Thanks shytalk I will get a splitter
Post by 4l04ever on Mar 6, 2017 11:44:05 GMT 1
Go to a shop who does the Goodridge Build-a-line kits and just get the parts you need.
Post by neo on Mar 6, 2017 14:20:23 GMT 1
Go to a shop who does the Goodridge Build-a-line kits and just get the parts you need. Cheers 4lo not many shops here believe it or not that offer that I'll look on internet see if I can find a local supplier
Post by neo on Mar 6, 2017 14:20:58 GMT 1
There should be a splitter bolted to the bottom yoke, I have got a 3 line set of hoses, can't remember if they're HEL or something else and I have a splitter if you don't have one, that would solve your problems 😄👍 Thanks shy I will look into it
Post by 4l04ever on Mar 6, 2017 15:16:44 GMT 1
I must be lucky as two local shops have them. B&J Bikes in Willenhall and QB Bikes in Quarry Bank.
Post by neo on Mar 6, 2017 16:05:43 GMT 1
f**k all around here sleepy sussex 😔
Post by wheelie250 on Mar 7, 2017 13:35:42 GMT 1
Please keep us advised as to how the project goes as I've been thinking about doing exactly the same thing.
Post by tony1964 on Mar 7, 2017 13:50:11 GMT 1
You could use a longer banjo bolt on the master cylinder and have 2 long hoses and do away with the splitter, friend did it on gsx1100 many years ago, looked good.
Post by tony1964 on Mar 7, 2017 13:56:51 GMT 1
Post by neo on Mar 10, 2017 8:36:32 GMT 1
Hi all thanks for you help however I have decided to sell the bike and possibly obtain a 31k save mucking about with it
Post by ellasae on Mar 13, 2017 18:29:38 GMT 1
That's a bit drastic , brake hoses aren't that much of an issue surely?
Post by neo on Mar 13, 2017 18:33:14 GMT 1
That's a bit drastic , brake hoses aren't that much of an issue surely? It is a drastic measure but.. i am not to sure how the bike will look with normal bars etc plus I can be assed to mess about with it I always fancied an lc2 so this has made my mind up, sold the f2 (reasonable I thought) injecting more money into an lc2.
Post by wheelie250 on Mar 15, 2017 14:17:13 GMT 1
How far did you get with the conversion project?? You obviously needed longer hoses but how about the throttle and clutch cables - were these long enough?? Also what about the switchgear, are the cables long enough?? As I posted earlier, I'm thinking about doing this conversion with my N2 (but I haven't got round to dragging it out yet and measuring things up) - I was hoping that you would do all the ground work for me!!!! lol
Post by neo on Mar 15, 2017 14:46:40 GMT 1
How far did you get with the conversion project?? You obviously needed longer hoses but how about the throttle and clutch cables - were these long enough?? Also what about the switchgear, are the cables long enough?? As I posted earlier, I'm thinking about doing this conversion with my N2 (but I haven't got round to dragging it out yet and measuring things up) - I was hoping that you would do all the ground work for me!!!! lol Lol well I would think the switchgear and the throttle cables are standard on 31k n1 f1 and f2 but I stand to be corrected.. I got the top yokes and the handlebars then the master cylinder cable ground me to a halt. I always wanted a 31k so I sold my f2 and a few other toys and am awaiting delivery of my 31k from mike (kopite 30) 👍 good luck with the conversion, I have top yokes if you need them??
Post by wheelie250 on Mar 15, 2017 15:00:12 GMT 1
I'm hoping that the wiring and cables will be long enough but the 31K bars do seem to be quite a bit higher than the clip-ons on the F2/N2 - hence you needing a longer brake hose. I'll have to extract my bike from the back of the garage and do some measuring up. If it does look like being a reasonably simple conversion then I would be looking for a 31K top yoke and handlebar set and would be very interested in yours. Cheers, Tony.
Forgot to say - nice 31K!!!!!
Post by neo on Mar 15, 2017 17:03:20 GMT 1
Forgot to say - nice 31K!!!!! No problem Tony, let me know, looking forward to getting the lc2
