Koso help
Mar 3, 2017 17:33:25 GMT 1
via mobile
Post by lrcarl on Mar 3, 2017 17:33:25 GMT 1
Please see video Clocks stay on with ignition off Time/date Does this seem right Bit clueless when it comes wiring Thanks carl
Post by Tobyjugs on Mar 3, 2017 18:01:55 GMT 1
Hi Carl, i cant see the video but the Koso systems generally have two power wires being red and brown. If you have connected it up correctly the time/date always stays on with all other functions out. The red wire should go on the positive battery side before the ignition switch and the brown wire on the power side after the ignition switch.
Easy to check if you disconnect the postive pole on the battery. Still with the ignition off if you re-connect the pole, the clocks it should go through the start cycle and the clock should start up at 00:00 and switch itself off again.
If you want all systems out until you put the ignition on, join the red and brown wire's together on the power feed after the ignition. The info i have given is general for Koso.
Koso help
Mar 3, 2017 18:24:42 GMT 1
via mobile
Post by lrcarl on Mar 3, 2017 18:24:42 GMT 1
Thanks Tony looks like it's all ok then Good tip putting both wires on output side of ignition carl
Post by Tobyjugs on Mar 3, 2017 18:39:25 GMT 1
It states it in the manual
Koso help
Mar 3, 2017 18:49:00 GMT 1
via mobile
Post by lrcarl on Mar 3, 2017 18:49:00 GMT 1
eBay purchase no manual Looked on line for diagram Carl
Post by LC_BOTT on Mar 18, 2017 10:04:48 GMT 1
Just a bump on this, as I'm thinking of getting one of these as well, how easy to fit are they, are they large enough to see when riding, and is the display bright enough on a sunny day?? (not sure if they are more car designed) How are you getting on with yours now??
cheers
Koso help
Mar 18, 2017 10:41:51 GMT 1
via mobile
Post by lrcarl on Mar 18, 2017 10:41:51 GMT 1
Easy enough to fit (if I can do it anyone can) Not had bike out yet so not sure about glare Carl
Post by LC_BOTT on Mar 18, 2017 11:06:24 GMT 1
Thanks, I know Yogi has one as well, but not sure that's been ridden yet either. hopefully see a few more replies Seen one for £160 so far, but there are a few different designs ones to chose from.
Post by Tobyjugs on Mar 18, 2017 11:14:17 GMT 1
They work well in the sun. Just remember if you connect it up according to Koso it will draw a small amount of charge from the battery for the clock function.
One other thing i bought one secondhand for myself and it was very slow to react in the rpm setting but this was a very basic model with only rpm, and temperature functions.
The other types i have seen have all worked very well.
Koso help
Mar 18, 2017 11:31:53 GMT 1
via mobile
Post by lrcarl on Mar 18, 2017 11:31:53 GMT 1
Thanks, I know Yogi has one as well, but not sure that's been ridden yet either. hopefully see a few more replies Seen one for £160 so far, but there are a few different designs ones to chose from. Fitted in line temp gauge on mine for accurate reading Not just hot/cold Best feature for me Carl
Post by JonW on Mar 18, 2017 13:12:03 GMT 1
Koso usa often has manuals online or will send you them, try there?
