Post by muttsnuts on Feb 24, 2017 10:54:33 GMT 1
Guys, just a quick question, is there only one type of belly pan/fitting for the lC or are there different types, I just need to make sure that an aftermarket pan is basically the same dimensions/fittings etc as say a pro-am one etc Any pointers/advice greatly recieved - not a topic I am that up on | - you can't know everything can you !! oh and if anybody has one not fitted that they could photo and send me some shots of it from different angles tha would be great Thanks in advance
Post by muttsnuts on Feb 24, 2017 12:48:41 GMT 1
LOL I laugh a lot, mainly at myself these days !
Post by copper99 on Feb 24, 2017 17:35:04 GMT 1
Post by copper99 on Feb 24, 2017 17:37:58 GMT 1
The genuine item comes with big clunky metal brackets but P clips as suggested by many , are much neater and easier to use to fit the belly pan.
Post by veg on Feb 24, 2017 21:45:15 GMT 1
Got a carbon one I can photo if that helps? Would this be related to exhaust fitting?
Post by muttsnuts on Feb 25, 2017 10:17:51 GMT 1
Hi copper99, yes that helps thanks
Veg, yes its related to the exhaust testing, its so when the pipes are modified they account for fitting a belly pan
Thanks for all of the help again
The next generation of pipe should fit the bill and has taken into account all of the feedback you guys provided, so you have all had some involvement in them being developed !
Post by rigga on Feb 25, 2017 14:44:25 GMT 1
Post by 67kev on Feb 28, 2017 15:31:03 GMT 1
Hi Mutts, surely someone local to you can lend you one to fit to your frame so that it's spot on? Where abouts are you? 67kev
