Post by petehodges on Feb 23, 2017 21:54:30 GMT 1
Post by petehodges on Feb 23, 2017 23:17:09 GMT 1
anyone ?
Post by Yogi on Feb 23, 2017 23:27:16 GMT 1
Pete are you sure the bearings all the way home
Post by petehodges on Feb 23, 2017 23:32:15 GMT 1
hi mate yes there right home i think it never had a seal that side as im thinking its been machined down to fit the arm or i,m missing a trick here
Post by Yogi on Feb 23, 2017 23:35:05 GMT 1
Why machine it down when you could just swap the spacer instead
Post by Yogi on Feb 23, 2017 23:36:27 GMT 1
Is the bearing the same width as the one you took out
Post by petehodges on Feb 23, 2017 23:40:14 GMT 1
yes mate ive reused same bearings as they were best part new the seal i got off norbo would fit the outside but the doesnt fit the spacers if that makes sense matt
Post by Yogi on Feb 23, 2017 23:46:56 GMT 1
I asked if the bearing was right home because I had trouble with one of mine after getting the hub powdercoated You can see if there's a gap if you look from the back If the inner part of the seals bigger than the spacer it might have been changed for the metmachex swinger
Post by petehodges on Feb 23, 2017 23:55:19 GMT 1
ill have another look at it tomorrow night matt & report back but im pretty sure there home , why is it with this fooking bike everything a problem ,sometimes i feel like breaking it up for spares !! any how thanks matt
Post by Yogi on Feb 23, 2017 23:58:56 GMT 1
Stick at it mate,be worth it in the end
That seal looks wrong to me,
I'll check mine tomorrow and put a pic up
Matt
Post by petehodges on Feb 24, 2017 0:12:04 GMT 1
Yer I'll put a pic up of the seal , tomorrow could be I've got wrong one cheers for help mate 👍
Post by midlifecrisisrd on Feb 24, 2017 11:01:43 GMT 1
There should be a seal there but it's only about 5mm thick
If it has been modded as you have a sealed bearing you can just make a new spacer with a flange on the end just smaller than the bearing size
Post by foxyjohn on Feb 24, 2017 17:43:38 GMT 1
The seal looks like the one that fits the speedo drive on the front wheel
Post by Shytalk on Feb 24, 2017 18:09:52 GMT 1
Post by petehodges on Feb 24, 2017 22:23:59 GMT 1
ahh thanks shytalk that was just what i was after mate thanks so MUCH right ive had a look & think i just need the right oil seal so i may have messed up when i ordered these off norbo so without sounding really dim , i dont really want too order another wrong seal have you got a part number or link to the one i need thanks again pete
Post by Yogi on Feb 24, 2017 22:25:52 GMT 1
I didn't bother putting the same pic up after Simon beat me to it,lol
Post by petehodges on Feb 24, 2017 22:30:35 GMT 1
yes cheers matt , i think its never had a seal & ive ordered or been sent the wrong one so should be easy to sort this
fingers crossed
Post by Yogi on Feb 24, 2017 22:31:29 GMT 1
One sec I'll put the part number up Number 13
Post by stusco on Feb 24, 2017 22:31:52 GMT 1
Post by stusco on Feb 24, 2017 22:40:21 GMT 1
Snap
Post by petehodges on Feb 24, 2017 22:49:08 GMT 1
thanks matt , stusco i take i could order this from fowlers ? i take it there still being made as ill get on the phone tomorrow
Post by Yogi on Feb 24, 2017 23:08:47 GMT 1
Replacement is in stock £8.20 Matt
Post by Yogi on Feb 24, 2017 23:10:42 GMT 1
It's been superseded with that part number
Post by petehodges on Feb 24, 2017 23:14:58 GMT 1
cheers matt nice one i get on it
