antos
Post by antos on Feb 5, 2017 21:44:38 GMT 1
Did a compression test today and its showing 95 psi on both cylinders bike has 22k miles anyone know what's the normal range? Thanks
Post by tsa on Feb 6, 2017 7:06:43 GMT 1
110psi is the norm but depends on how accurate the gauge is really.
antos
Post by antos on Feb 6, 2017 9:32:33 GMT 1
Thank you sir π It's a new one so should be somewhere nearπ So really my 95 reading is a bit below par but should still run ok me thinks.
begbie
Post by begbie on Feb 13, 2017 1:24:58 GMT 1
Depends on gauge calibration and how you use it. wot and kick til gage stops moving, 5-7 kicks on mine.
Post by bare on Feb 13, 2017 4:21:27 GMT 1
Compression tests are ambiguous. Two testers will often get differing results on the same engine with the same test gear. That said: 95 psi = rebuild time.
antos
Post by antos on Feb 13, 2017 15:23:16 GMT 1
Thanks mate, it's coming to bits soon ,ordered the tools and the frame is nearly stripped ready for powderπ
Post by bare on Feb 13, 2017 19:40:51 GMT 1
Glad that helps. Personally I'd rattle can spray a frame rather than powder coat it. Looks better with oem style paintwork and doesn't result in screwhole and fit issues either
