Post by russpuss on Jan 15, 2017 12:49:53 GMT 1
My German mirrors don't have the knuckles or any rubber rings around the outside (hopefully that makes sense?).
Tried the old google search and seems UK ones do have, is there a cheap aftermarket pair with those fitted that I can butcher both pairs to make mine UK looking?
Post by oldelsieboy on Jan 15, 2017 13:01:52 GMT 1
My German mirrors don't have the knuckles or any rubber rings around the outside (hopefully that makes sense?). Tried the old google search and seems UK ones do have, is there a cheap aftermarket pair with those fitted that I can butcher both pairs to make mine UK looking? Most aftermarket UK spec mirrors are supplied with rubber rings & AFAIK they will fit OEM mirrors, the problem I have found tho is with the knuckle section on pattern mirrors, they always seem to be loose & cannot be tightened enough to stay in the correct position. HTH OEB
Post by 4l04ever on Jan 16, 2017 9:01:02 GMT 1
Post by midlifecrisisrd on Jan 16, 2017 11:02:04 GMT 1
I bought a pair of the chrome ones off fowlwers ( cant remember if SR or was some DT ) and they look good (not used yet) but never had the Yam emblem on them. I wondered whether they no longer had it hence the cheap price or somebody did the old order genuine and swap for pattern before returning Steve
Post by russpuss on Jan 16, 2017 11:05:47 GMT 1
Don't fancy chrome, may just stick with the Non-knuckle if they are rubbish?
Post by 4l04ever on Jan 16, 2017 13:13:06 GMT 1
The SR125 ones do not have Yamaha logs on them, but they do not move even at German Autobahn speeds....
