Post by petehodges on Jan 9, 2017 22:29:22 GMT 1
hi all got a bit of polishing too do in man cave soon swinging arm , forks ect so im after a decent polisher i want something that has got plenty of gutts & will last me as some look a bit cheap n nasty on ebay i hate buying cheap shit tools then having too buy again seen some with 200 watt motor? what you got ? cheers
Post by midlifecrisisrd on Jan 9, 2017 22:31:31 GMT 1
I just use a decent bench grinder with the spindle ends you get off ebay to take the polishing wheels
Post by Ozhammer on Jan 9, 2017 23:37:16 GMT 1
+1
That way you can convert back to a grinder if you need to.
Rgds Ozhammer
Post by jackjabba on Jan 10, 2017 11:33:25 GMT 1
Get the most powerful one you can afford. Cheap ones stall when you start putting on the pressure and you will get pissed off with it. Some people just use the motor from an old washing machine as they have loads of torque.
Post by vic6169 on Jan 10, 2017 12:32:41 GMT 1
350Watts are better as they don't slow under pressure.
Post by Norbo on Jan 10, 2017 14:07:52 GMT 1
any good 8" one is what you want half a horse if you go a 1 house one the revs half and you need the rpm to get a good finish .
Post by Deleted on Jan 10, 2017 14:54:03 GMT 1
As JJ says washing machine motors are the go
Crompton & Parkinson 1428rpm will do it nicely, they are easy to find too, we used one to drive an old Myford lathe
