Post by petehodges on Dec 27, 2016 21:37:59 GMT 1
Ok I'm thinking of jazzing my Lc up a little I'm think of changing it too polished edges Lc wheels what you all think ? Anygot a pic of there bike if it's similar to mine What do you all think I'm happy to take stick & criticism Cheers lads
Post by sparx on Dec 27, 2016 21:42:20 GMT 1
Standard lc wheels will make it look a lot more original. Looks like they are 31k forks too which makes the mudguard sit a little weird
Post by petehodges on Dec 27, 2016 22:18:40 GMT 1
thanks sparx these were on it when i got it years ago anyone know if lc wheels will go straight on ? im sure i read on here they do
Post by oldelsieboy on Dec 27, 2016 22:25:18 GMT 1
Forks are LC, 4L0/1.
LC wheels will fit but you would have to loose the disc brake on the rear.
OEB
Post by wallcraft on Dec 27, 2016 22:42:05 GMT 1
Look like standard 4lo forks to me! Major work to get the standard back wheel in if retaining the disc set up, I would put a standard back wheel with the drum set up, looks a bit clumsy at the mo. Front standard wheel with standard discs will drop straight in but again will need work to get those calliper brackets to match up. Keep the callipers but look into getting the right calliper bracket for the standard disc set up, NK racing does them. Will work very well. Very Nice bike though. Mark.
Post by 4l04ever on Dec 27, 2016 22:49:29 GMT 1
You can fit TZR125 3-spoke wheels. 4FL model rear and 3PC front. Polished rims too...
Post by Tobyjugs on Dec 27, 2016 23:21:17 GMT 1
Nice photo
Post by petehodges on Dec 27, 2016 23:32:32 GMT 1
You can fit TZR125 3-spoke wheels. 4FL model rear and 3PC front. Polished rims too... thanks so your saying they shoild drop straight in ? been looking on ebay but cant find 4fl model ? thanks pete
Post by petehodges on Dec 27, 2016 23:34:48 GMT 1
Look like standard 4lo forks to me! Major work to get the standard back wheel in if retaining the disc set up, I would put a standard back wheel with the drum set up, looks a bit clumsy at the mo. Front standard wheel with standard discs will drop straight in but again will need work to get those calliper brackets to match up. Keep the callipers but look into getting the right calliper bracket for the standard disc set up, NK racing does them. Will work very well. Very Nice bike though. Mark. thanks for comments mark if i can i really dont want to lose rear disc as will have to change arm as well then thats one of the things i like on my bike
Post by wallcraft on Dec 27, 2016 23:42:11 GMT 1
Look like standard 4lo forks to me! Major work to get the standard back wheel in if retaining the disc set up, I would put a standard back wheel with the drum set up, looks a bit clumsy at the mo. Front standard wheel with standard discs will drop straight in but again will need work to get those calliper brackets to match up. Keep the callipers but look into getting the right calliper bracket for the standard disc set up, NK racing does them. Will work very well. Very Nice bike though. Mark. thanks for comments mark if i can i really dont want to lose rear disc as will have to change arm as well then thats one of the things i like on my bike Yeh know what you mean, if it was straight forward to fit the disc and calliper set up to the 4lo wheel, I'd of done it by now. Love the pipes, waiting for Kenny to finish mine, can't wait. You impressed with them? Mark.
Post by wallcraft on Dec 27, 2016 23:45:47 GMT 1
You can fit TZR125 3-spoke wheels. 4FL model rear and 3PC front. Polished rims too... thanks so your saying they shoild drop straight in ? been looking on ebay but cant find 4fl model ? thanks pete Love the action picture of the mean machine Rob,looks a proper LC. Reminds of Tobyjugs R6 clad LC!
Post by 4l04ever on Dec 28, 2016 0:37:11 GMT 1
You can fit TZR125 3-spoke wheels. 4FL model rear and 3PC front. Polished rims too... thanks so your saying they shoild drop straight in ? been looking on ebay but cant find 4fl model ? thanks pete The 3PC front wheel fits straight in. Just need to adjust calliper brackets to centre the wheel. I modified a 2MA rear sprocket carrier to fit in the 4FL rear wheel. Had the lip machined off for the outer seal and used a sealed bearing instead. NK Racing made the calliper hanger and spacers. I think 4HW are the same as 4FL. Rear wheel is a 3.5" by 17"
Post by bare on Dec 28, 2016 6:08:16 GMT 1
Suggest you Do Not go to 17" wheels.. They just Look 'wrong' on an LC or Valvie. (spare me :-) LC wheels are too thin. Your Valvie wheels are a bit wider allowing tires to Not be pinched in IMO the Worst part about your early valvie wheels is their Colour. Dull Lifeless flat black doesn't even look good on a BBq. Try painting them any other colour .. First? I would.
Post by dusty350 on Dec 28, 2016 10:05:14 GMT 1
Hi Pete, I don't think you will get a definitive answer to your question - there are so many opinions as to what looks right or wrong that getting an overall decision is not gonna happen !! I like the early pv wheels with the holes more than the later "slotted" type, but the slots are a lighter wheel if weight is an issue. As Bare said, a repaint would lift the whole look of the bike - the wheels are a big surface area so a different colour would have a big impact. If cost and hassle are an issue, repainting what you have will be the easiest option, plus you keep the brakes and there are no engineering jobs to do. I like hybrids and all mine have 3 spoke wheels which, imo, look awesome and work well but it's each to their own, and the fact that your bike is a hybrid anyway means you can do your own thing more readily. Here is a comparison - I swapped the black wheels on my recently sold Lc for white wheels, did the back wheel first; Now whilst white wheels aren't everybody's thing, I thought the transformation was amazing; And my old 400 had "different" pv wheels; Dusty
Post by veg on Dec 28, 2016 10:45:07 GMT 1
The problem you may have going to LC wheels is your calipers I have ap calipers and they are deeper than standard 4lo calipers so may interfere with the spokes on 4lo wheels.
Post by oldelsieboy on Dec 28, 2016 12:35:45 GMT 1
The problem you may have going to LC wheels is your calipers I have ap calipers and they are deeper than standard 4lo calipers so may interfere with the spokes on 4lo wheels. AP Calipers should not interfere with the LC wheel spokes when fitted to standard forks, was a popular upgrade BITD. OEB
Post by veg on Dec 28, 2016 12:47:12 GMT 1
There you go straight from OEB they re fine
Post by richclare on Dec 28, 2016 18:42:16 GMT 1
Hi Pete,
Nice bike and I quite like the black wheels as they are! As Dusty said, it comes down to taste. Dusty's pics also show perfectly the difference and effect between the white and standard colours - personally I like the both, but each gives a certain style. I went through weeks of searching and looking at photos of LC wheels for my current bike!!!! In the end, I decided on standard for my project as it seems to go with most colour schemes and look classic.
Good luck with your choice ....
Rich
Post by richclare on Dec 28, 2016 18:46:49 GMT 1
The problem you may have going to LC wheels is your calipers I have ap calipers and they are deeper than standard 4lo calipers so may interfere with the spokes on 4lo wheels. AP Calipers should not interfere with the LC wheel spokes when fitted to standard forks, was a popular upgrade BITD. OEB Are these both your bikes OEB? Like the yellow and black one..... a lot! Rich
Post by oldelsieboy on Dec 28, 2016 19:05:19 GMT 1
AP Calipers should not interfere with the LC wheel spokes when fitted to standard forks, was a popular upgrade BITD. OEB Are these both your bikes OEB? Like the yellow and black one..... a lot! Rich Nope, not mine. OEB
Post by petehodges on Dec 29, 2016 13:52:21 GMT 1
Hi Pete, I don't think you will get a definitive answer to your question - there are so many opinions as to what looks right or wrong that getting an overall decision is not gonna happen !! I like the early pv wheels with the holes more than the later "slotted" type, but the slots are a lighter wheel if weight is an issue. As Bare said, a repaint would lift the whole look of the bike - the wheels are a big surface area so a different colour would have a big impact. If cost and hassle are an issue, repainting what you have will be the easiest option, plus you keep the brakes and there are no engineering jobs to do. I like hybrids and all mine have 3 spoke wheels which, imo, look awesome and work well but it's each to their own, and the fact that your bike is a hybrid anyway means you can do your own thing more readily. Here is a comparison - I swapped the black wheels on my recently sold Lc for white wheels, did the back wheel first; Now whilst white wheels aren't everybody's thing, I thought the transformation was amazing; And my old 400 had "different" pv wheels; Dusty thanks lads &dusty yer sure i not really sure what to do but i think it just looks a bit plan at mo has any got any pics of polished rims pv on a lc i might try put my n1 wheels on too see the diffrence but thanks for your advice trouble is im not really that much off a bike builder but i do try cheers pete
Post by dusty350 on Dec 29, 2016 15:05:51 GMT 1
Hi Pete The hard work looks to have been done on your bike already A pv rear wheel wont slot straight in to an arm designed for an Lc wheel, so your swingarm is either an arm designed for an Lc frame/pv rear wheel, or more likely the caliper carrier has been made so it will fit with the wheel into an arm designed for an Lc wheel. I understand what you mean about the colours - when I got my carbon Lc project it was all black/carbon coloured and looked too much for my taste. There is minimal alloy or chrome on show on these bikes - not like their predecessors that had chrome mudguards, fuel caps, bars etc. As a cheap experiment, why don't you try some coloured rim tape on your wheels ? Loads of different colours on ebay and it is an easy way to make an instant impact. Dusty
Post by bare on Dec 29, 2016 20:06:50 GMT 1
Polishing rims, especially ones that have been painted over, is Not a trivial task. Lotsa hours involved. Just saying.
Post by Tobyjugs on Dec 29, 2016 22:28:38 GMT 1
thanks so your saying they shoild drop straight in ? been looking on ebay but cant find 4fl model ? thanks pete Love the action picture of the mean machine Rob,looks a proper LC. Reminds of Tobyjugs R6 clad LC! Thanks for the kind comment wallcraft. My engine is now built up in it's final form. I should update the thread.
Post by petehodges on Jan 1, 2017 23:17:25 GMT 1
Post by petehodges on Jan 1, 2017 23:27:42 GMT 1
Post by rich on Jan 2, 2017 0:06:08 GMT 1
Yeah they are all the same size. I once ran Lockheeds on my LC with LC2 wheels - worked great but the bleed nipples were scary close to the hub on the inside!
Post by petehodges on Jan 2, 2017 0:13:41 GMT 1
Yeah they are all the same size. I once ran Lockheeds on my LC with LC2 wheels - worked great but the bleed nipples were scary close to the hub on the inside! yer i know rich theres only a few mm in it your bike looks really sweet mate a credit too you
