Post by Shytalk on Dec 27, 2016 18:55:39 GMT 1
Post by Yogi on Dec 27, 2016 19:08:36 GMT 1
Blimey it come up like new
Well done that man
Matt
Post by Shytalk on Dec 27, 2016 19:46:04 GMT 1
Yes she was impressed too, they are much clearer now, next one will be an F1 screen.
Post by marsbar350 on Dec 27, 2016 20:12:02 GMT 1
Exhaust still hanging on?
Post by Shytalk on Dec 27, 2016 20:41:42 GMT 1
Exhaust still hanging on? Hi Andy, of course it is, wouldn't have expected less 👍
Post by LC_BOTT on Dec 27, 2016 20:53:54 GMT 1
Wow that's impressive, what did you use, my daughters got a Micra, and was going to do hers soon, I tried with an orbital polisher last time, but the shine didn't last that long, and I didn't get them looking that good.
every little helps as the lights are truely sh###e, (and a common problem too), has it improved the road vision much??
Post by Shytalk on Dec 28, 2016 11:40:13 GMT 1
Wow that's impressive, what did you use, my daughters got a Micra, and was going to do hers soon, I tried with an orbital polisher last time, but the shine didn't last that long, and I didn't get them looking that good. every little helps as the lights are truely sh###e, (and a common problem too), has it improved the road vision much?? I used the same stuff I've done screens with before, if you search my posts you'll find everything there, I started off with P2000 wet and dry then scratch remover. She hasn't taken it out yet but I'd say they're 💯 % brighter, it's not permanent but should last for around 12 months before it'll need redoing.
Post by Deleted on Dec 29, 2016 14:54:58 GMT 1
The "plastic£ has a special coating on it which when sanded/polished gets removed
they will yellow again after a year or so, not a lot you can do to stop it
One thing that is useful is UV Cut bulbs
Post by andyr1rider on Dec 30, 2016 13:35:50 GMT 1
Really impressive, did you use an orbital sander or did you polish the lights by hand?
Post by Shytalk on Dec 30, 2016 13:41:01 GMT 1
Really impressive, did you use an orbital sander or did you polish the lights by hand? I use a drill on the slower speed and 3" pads.
