Post by bezzer on Dec 18, 2016 14:42:11 GMT 1
Chaps, Open question : Is it possible and if so is there any benefit from fitting 31K forks into a 4LO?. I read the stanchions are slightly thicker than the earlier 250/350 lc's. I'd like to keep the standard look and thought they'd flex less. Would the standard 4LO calipers fit the 31K lowers, and would the discs be aligned?, I intend to use the standard wheel if poss.
Your thoughts and comments are welcomed and always appreciated.
ATB bezzer.
Post by veg on Dec 18, 2016 16:24:31 GMT 1
I'm using them in my 4lo as far as I know yes yes and yes
Post by dave1963 on Dec 18, 2016 17:33:21 GMT 1
All you need is the yokes everything else fits i have them in my 4lo good cheap upgrade
Post by bare on Dec 18, 2016 18:09:19 GMT 1
AS above they fit like they were intended to. One caveat; The springs are Too Soft for anything other than Shopping rides Fitting a higher rate spring is essential for improved handling. Cut 4 or more coils of the 31k springs and a fit a length of PVC tubing as spacers to compensate for the springs' reduced length.
Post by bezzer on Dec 18, 2016 18:34:48 GMT 1
Thanks everyone for your responses, I knew I'd get good advice from members of this excellent forum.
