Post by petehodges on Dec 11, 2016 9:50:48 GMT 1
Hi lads I'm after a rear brake stop switch spring for Lc it Measures 110mm anyone got one or a link ? Ta
Post by stusco on Dec 11, 2016 12:14:38 GMT 1
Got mine from Norbo
Post by veg on Dec 11, 2016 12:31:56 GMT 1
Just measured mine which is off the bike and its 85mm in static unstretched form
Post by oldelsieboy on Dec 11, 2016 12:54:21 GMT 1
Just measured mine which is off the bike and its 85mm in static unstretched form ^^^ Ditto ^^^ No idea what this one is off tho OEB
Post by petehodges on Dec 11, 2016 13:14:47 GMT 1
Just measured mine which is off the bike and its 85mm in static unstretched form ^^^ Ditto ^^^ No idea what this one is off tho OEB That's the size I'm after OEB as I'm running tarozzi sets I think the 85mm one will pull the switch down all the time ?? Or am I wrong ??
Post by veg on Dec 11, 2016 13:20:51 GMT 1
I understand then you have rear sets
Post by markhoopy on Dec 11, 2016 13:37:33 GMT 1
You can buy switch springs that can be cut and bent to suit if you can't find one the correct length.
Post by markhoopy on Dec 11, 2016 13:40:34 GMT 1
Post by oldelsieboy on Dec 11, 2016 14:07:53 GMT 1
^^^ Ditto ^^^ No idea what this one is off tho OEB That's the size I'm after OEB as I'm running tarozzi sets I think the 85mm one will pull the switch down all the time ?? Or am I wrong ?? If you want it message me your address & I'll get it posted, all I ask is that you deposit a fiver in the next Cancer Research Charity box you see. OEB
Post by Norbo on Dec 12, 2016 18:10:03 GMT 1
The idea with thois type is that you can cut them shorter and bent it round at the e nd so they fit many different bikes
