Post by chrismac on Nov 6, 2005 21:24:21 GMT 1
I'm putting an RD 250 LC back together, its been in boxes for about 5 years. I've had most the parts I need from Norbo. but can anybody recommend paint to make my cylinders, exhausts and engine side covers look like new again? and where can I get it from?
Post by vinze187 on Nov 6, 2005 21:29:04 GMT 1
as a quick answer for the cylinders id use hammerite high temp engine paint but wait for conformation from norbo, if you look at nutter2200 home page theres a piccy on there of the finish norbo gets with what ever paint he uses
Post by Norbo on Nov 7, 2005 11:24:52 GMT 1
There are many paints that are good and i vave used loads of types. I use firecoat as a bace coat and heat dispersment paint for barrels and the same firecoat on the exhoursts but Spirex engine enamel as the finishing coat but only 1 thin coat as i dont like a very hi glos finish . I like a satin finish. Nutters barrels where the first i have used the heat dispersment on and i realy like how they look so i will be doing them all with it from now on . It gives a slitely textured look that looks realy nice.
4l0
Post by 4l0 on Nov 7, 2005 17:11:53 GMT 1
I'm putting an RD 250 LC back together, its been in boxes for about 5 years. I've had most the parts I need from Norbo. but can anybody recommend paint to make my cylinders, exhausts and engine side covers look like new again? and where can I get it from? i use satin pj1 on barrels and exhausts
Post by Norbo on Nov 7, 2005 23:09:58 GMT 1
PJ1 is good as well.
Post by chrismac on Nov 10, 2005 20:26:14 GMT 1
Thanks for all the help. Looks like this is my job for the weekend!!
Post by Norbo on Nov 11, 2005 12:18:10 GMT 1
Only thing to add is Spray them hot heat them up infront of the fire dont spray cold or the paint will go white and may run. the hotter the better .
Post by chrismac on Nov 11, 2005 19:33:11 GMT 1
cheers for the tip Norbo
