horace
Post by horace on Nov 12, 2016 10:25:01 GMT 1
Hi , balancing f2 carbs , got both slides lifting spot on together , then checking carb body windows one slide dot in visible but one isn't , if I adjust so there both in together they go out of sink , is it down to a crappie cable or am I missing something ?
Post by davey on Nov 12, 2016 11:07:07 GMT 1
I would go for a gen yam cable , i had issues with my 4l1 running to rich and after taking advice from from Gary (arrow) i sorted it all out , the majority of the issues was a pattern cable . I didnt realize that such small alterations and adjustments would have such a big effect so its imperative IMO to go genuine yamaha cables .
horace
Post by horace on Nov 12, 2016 12:47:11 GMT 1
Thanks , that's what I've been thinking , will try and find one I think.
Post by arrow on Nov 12, 2016 12:53:46 GMT 1
Norbo has decent cables.
horace
Post by horace on Nov 12, 2016 15:11:16 GMT 1
Cheers Gary , am going to try and get a gen yam one , I no there a bit expensive but even the good pattern ones can be a bit hit and miss, like Davey is saying a few mm difference and your struggling ,
Post by mattybeckett on Nov 12, 2016 16:50:57 GMT 1
I had same problem with yam bits cable, bought a decent £30.00 one from norbo all spot on now .
Post by rich on Nov 13, 2016 21:50:14 GMT 1
if you know the slides are physically in synch, I wouldn't worry about the windows. They are inaccurate anyway
Post by muddyfox on Nov 14, 2016 14:36:48 GMT 1
bbq stick method, just make sure the mouths of the carbs are clear of slides when on WOT!
Post by rich on Nov 14, 2016 15:29:14 GMT 1
Drill bit under the slides to set the idle screws the same. Then synch the cables to make sure the slides lift by the same amount and at the same time. As above, look down the back of the carbs and make sure the slides disappear at the same time on WOT.
Post by stusco on Nov 14, 2016 16:34:47 GMT 1
What throttle cable and on what bike I was using f2throttle with an lc cable I couldn't get the carbs to adjust correctly ,I had to alter the throttle tube to get a full pull
