Post by allspeeds on Nov 7, 2016 20:28:15 GMT 1
Can anybody give me the Battery number for a Yuasa in a F2 please. Thanks
Post by Yogi on Nov 7, 2016 20:43:17 GMT 1
YB5L-B yuasa Matt
Post by allspeeds on Nov 7, 2016 20:52:27 GMT 1
Thanks Matt
Post by wwwRD350LCnet on Nov 8, 2016 8:37:06 GMT 1
The F2 should have a smaller 4 Ah instead of 5 Ah battery which was introduced to save weight like thicker brake disks and new wheels. Check page 2 of this file: www.rd350lc.net/1WTfilePress.pdfOld microfiche says GM4A-3B battery model (4 Ah) and since this battery is less long, there is a small rigid foam block glued in the plastic box to avoid any play of the battery (see part 10 microfiche E15). But now Yamaha microfiche at dealer has the information YB5L-B yuasa, and anyway most of the time, people fit the previous battery model and so the small foam block was removed by previous owner. So if you are not an anorak, the YB5L-B yuasa is fine ! Xavier
Post by LC_BOTT on Nov 8, 2016 9:38:12 GMT 1
Didn't realise that, what's the smallest battery you can fit? was thinking of going for a lithium on my next rebuild.
Post by midlifecrisisrd on Nov 8, 2016 9:41:53 GMT 1
Nearly posted yesterday but thought I would just be being picky
I always thought the UK bikes were 5.5A for the lc2 then 5A for the F2 then going back to 5,5A for the last ones
Its also what the aftermarket catalogues say
Now I'm confused lol
Post by jackjabba on Nov 8, 2016 9:48:43 GMT 1
Didn't realise that, what's the smallest battery you can fit? was thinking of going for a lithium on my next rebuild. If you don't already use Lithium batteries remember to factor in the cost of a good charger when you get your first one.
Post by wwwRD350LCnet on Nov 8, 2016 11:13:51 GMT 1
4L0 & 4L1 microfiche says: 131-82110-79 12N5.5-3b so 5.5AH and YAMAHA technical info too: On RD350LC2 31K microfiche says 131-82110-79 Yamaha technical information for the RD350LC2 31K - 12N5.5-3b: RD350F 57V microfiche says: 131-82110-61 Yamaha technical info 12N5.5-3b RD350F2 1WT microfiche says 43F-82110-60 GM4A-3B Yamaha technical info says nothing But I think that smaller battery for the F2 was a commercial argument but then to avoid to have 2 different batteries at YAMAHA dealers and since the F2 battery box can still receive the old one, they have simplified by unifying on the previous one...
Post by Norbo on Nov 8, 2016 12:15:43 GMT 1
some run the smaller some run a normal one fitted to 31k and LC i have found its a bit random
Post by allspeeds on Nov 8, 2016 12:38:17 GMT 1
Thanks for the info I'm not an anorak so will but a yb5l-b in it. Cheers
Post by midlifecrisisrd on Nov 8, 2016 14:26:47 GMT 1
Good info
I've just been putting the 5's in my last few
Post by wwwRD350LCnet on Nov 8, 2016 18:24:44 GMT 1
Yes ! to conclude, 4, 5 or 5.5Ah as soon as it fits the battery box, it will work Xavier
Post by lrcarl on Nov 8, 2016 18:43:58 GMT 1
Didn't realise that, what's the smallest battery you can fit? was thinking of going for a lithium on my next rebuild. Just bought lithium for mine 115mm-95mm-60mm Carl
