Post by petehodges on Nov 3, 2016 23:33:10 GMT 1
hi all as above had my bike on dyno tonight but as soon as it hits 7k the clutch slips really bad the guy dynoing told me too get some heavy duty clutch plates i just thought id ask those in the know before i buy the wrong parts heres run down on my bike 350 barrels tsa pipes mick abbey fast road tune , light flywheel
dont really want to spend on lock up clutch as ive parted with a good ££££££££ lately thanks pete
Post by markhoopy on Nov 3, 2016 23:48:40 GMT 1
Post by 84rzrider on Nov 4, 2016 3:12:59 GMT 1
Just went through this on my 84 RZ (YVPS) I ordered a set of FZR 1000 frictions, tossed the rubbers and installed a set of EBC heavy duty springs. If the bike has any miles on it at all check and or replace the steels as well (mine were warped). I tried Barnett springs and the pull was carpal tunnel surgery waiting to happen. The EBC springs work perfectly and no slip or drag with Toomey Chambers Spec II stage I port and head shaved .030 with VM 30s...
Post by JonW on Nov 4, 2016 3:32:34 GMT 1
If you reused your old springs even with new plates thats where you went wrong. On the advice of an Aussie forumer I measured a big box of plates and springs I have here from an ex-racer. All the springs were out of spec, but almost all the plates were fine.
With your motor you shouldnt even need any HD springs or plates really, new OEM ones are cheap too.
If you do fit HD springs, just fit 3 and 3 new OEMs, that lightens up the pull a bit.
Post by petehodges on Nov 4, 2016 8:15:35 GMT 1
Thanks for all replys lads So would you just change Springs or go the hole lot & clutch plates as well ? I had my engine rebuild a couple years ago & can't remember what he done with the clutch think it's standard Ta
Post by stusco on Nov 4, 2016 8:41:35 GMT 1
Same spec as mine new springs work fine
Post by headcoats on Nov 4, 2016 9:18:06 GMT 1
Yes use 3 x heavy duty and 3 original springs and just stagger them round the clutch
Part number I got for FZR friction plates is
4H7-16321-02
Post by petehodges on Nov 4, 2016 9:20:56 GMT 1
4H7-16321-02 Where you get them from mate ? Plates ? 👍
Post by Norbo on Nov 4, 2016 9:46:53 GMT 1
My clutch plats are R6 Race plates so i allready do them as a standard up gread for LV & YPVS i all so have TZ springs for the 3 & 3 or YZR500 springs if you prefer a full set of 6 the same .
Post by headcoats on Nov 4, 2016 10:35:09 GMT 1
I had mine from Norbo several years a go and although Norbo's not being genuine , mine have lasted since 2009 on a 68bhp tuned YPVS
(The above number is for genuine)
Post by 4l04ever on Nov 4, 2016 12:49:32 GMT 1
You can change oil to ATF fluid to help stop slipping. There is also GL4 gearbox oil, which helps with neutral issues, but not sure it makes slipping better or worse.
Post by Tobyjugs on Nov 4, 2016 18:04:39 GMT 1
I use the gl4 gearbox oil with standard clutch and 3 tz springs the engine is about 70 hp no slipping. The clutch action was horrible and when i changed the position of the handle bars i bought a second hand original R6 cable. This had an effect of making it smoother and it felt a little lighter as well
Post by bare on Nov 4, 2016 18:16:00 GMT 1
OEM clutch springs, GL4 oil, Ferodo Fz600/ early R6 race frictions. NO slip.. Ever. With oem Light action clutch Engine is mid 60s rear wheel hp.
Post by steeley on Nov 4, 2016 19:31:57 GMT 1
Hi , make sure the springs are in spec, as long as the frictions are ok also take 2 steel plates out and put 2 aircooled rd steel plates in . It sort of packs the clutch stack out a bit instead of big springs or washers under the springs.
Post by bare on Nov 6, 2016 17:43:06 GMT 1
OR.. add Another oem thin steel 350 plate to the stack... at the bottom of the basket. Ali face to Friction is a poor setup and the extra plate also thickens the stack usably.
Post by petehodges on Nov 6, 2016 22:35:40 GMT 1
cheers lads went with norbo in the end r6 plates 3x normal springs 3x rz springs as allways thanks for advice oh & bare i do have another ypvs plate around so i might pop it in thanks
