Post by looey on Nov 2, 2016 10:21:01 GMT 1
Anyone know for sure what make/type this liner is ?. Got 90% of it out so far. Just doing an Acetone test to see if it disolves it. It's slightly creamy white and very shiny. Cheers
Post by fredrikspansk on Nov 2, 2016 10:43:22 GMT 1
It looks like KREEM i used in a tank like 15 years ago
Post by foxyjohn on Nov 2, 2016 11:21:23 GMT 1
+ 1 for Kreem
Post by looey on Nov 2, 2016 12:05:58 GMT 1
God knows why it was poured in there in the first place. The tank has minimal surface rust and doesn't leak, looks like it was just poured in there without any prep whatsoever
Post by JonW on Nov 2, 2016 12:39:04 GMT 1
Kreeme do a remover IIRC, worth looking for as its a shit product and modern petrol will have it coming out in sheets... tho you could just leave some fuel in it instead of the expensive remover of course LOL
Post by looey on Nov 2, 2016 14:12:01 GMT 1
Yeah I've got it all out now, all bar a few stubborn bits right at the bottom, the rest can stay. It usually just comes away in large chucks, so doesn't cause blockages or carb probs. Got 3 litres of Deox-C in the tank now getting shot of the surface rust. Acetone doesn't seem to touch the liner, got a small piece in soak, hasn't touched it in the slightest .
Post by jackjabba on Nov 2, 2016 14:55:13 GMT 1
Try DCM rather than Acetone
Post by JonW on Nov 2, 2016 22:45:42 GMT 1
DCM?
Post by looey on Nov 2, 2016 22:48:16 GMT 1
I assume Dichloromethane (DCM) ?.
About £20 for 5L
Post by JonW on Nov 2, 2016 23:04:07 GMT 1
If so thats the active ingredient in paint stripper isnt it?
Post by Deleted on Nov 3, 2016 8:20:32 GMT 1
yep, removes anything organic
Post by midlifecrisisrd on Nov 3, 2016 9:34:36 GMT 1
That's the stuff
Bought 2.5L for about £11 at the beginning of the year
Will strip most paint off easily. Strangely it would not remove the paint off my switchgear. Softened but not stripped.
Don't leave the lid off, it evaporates quickly
Post by jackjabba on Nov 3, 2016 10:35:26 GMT 1
It stinks as well and will melt the soles of your shoes.
